Samson Tires?
   / Samson Tires? #1
cyclewacko
I cut a tire on my Kubota M4900 over the weekend, and I'm trying to decide what to do about it. The tires are pretty rock- and weather-worn, and I'm thinking about replacing both rears, rather than having the tire repaired. A local tire dealer has a Samson brand tire (made in China, I think) for a pretty good price. Has anyone used that brand, and if so, what do you think of them?
Thanks,
cyclewacko
   / Samson Tires? #2
I got a set on my ford 850 loader tractor.. had them for a couple years now.. way better thant he bald and leaking ones I had on it before.. good competitive price too.
soundguy
   / Samson Tires? #3
soundguy
I know this thread is 3+ years old but I was wondering how well the Samson tires are holding up / or held up. I have a set in my radar priced at $200.00 each. Other brands are upwards to $300 $400 each.
Thanks,
Kent
   / Samson Tires?
Thanks,
Kent
Kent:
I ended up buying the Sampson rear tires, and they are holding up just fine! I live in very rocky terrain, but the tractor does not see heavy use, although it's parked under a tree, so it does get a lot of sunlight on the tires. Hope that helps!
Regards,
Scott
   / Samson Tires? #5
Samson sells a lot of truck tires...
   / Samson Tires? #6
Thanks,
Kent
still fine. added a backhoe to that tractor now too!
   / Samson Tires? #7
Well the same place (Pep Boys) who quoted me $440 on the Firestone 8 ply tires found out that they can get the Samsonsn(4 ply) for $173.16 each.
With two new tires, tubes and mounting I will be out the door for less than $500.00
I almost went with the Firestone tires but at over twice the price I decided to go cheap for now. I'll drop my rims off tomorrow morning and have new tires by the end of the day.
My old tires are Firestone but I think they are only 4 ply.
Kent B.
   / Samson Tires? #8
Kent B.
Is that for front's or rears? I really need new front tires. I could "use" rear's but my current ones are filled with rimguard, and I don't know if I want to tackle that project!
   / Samson Tires? #9
Those prices are for the rear 11.2 x 24
I bought the Carlyle tires for the front already. I think that they were $ 90.00 plus tubes and mounting
"Neece" is the name of the heavy equipment shop with the HIGH prices. They are $100 over priced on everything.
One of my new front tires went flat a day after they were mounted. Pep-Boys replaced the tube for free... as they should.
Some of the work that they do is free anyway so I think that I will keep using them as much as possible.
   / Samson Tires? #10
fronts are generally less than 100$.. even tsc usually carries some..
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2015 Mack GU813 Mixer Concrete Truck, VIN # 1M2AX13C0FM028499 (A51572)
2015 Mack GU813...
