Samson Tires?
   / Samson Tires? #1
cyclewacko
I cut a tire on my Kubota M4900 over the weekend, and I'm trying to decide what to do about it. The tires are pretty rock- and weather-worn, and I'm thinking about replacing both rears, rather than having the tire repaired. A local tire dealer has a Samson brand tire (made in China, I think) for a pretty good price. Has anyone used that brand, and if so, what do you think of them?
Thanks,
cyclewacko
   / Samson Tires? #2
I got a set on my ford 850 loader tractor.. had them for a couple years now.. way better thant he bald and leaking ones I had on it before.. good competitive price too.
soundguy
   / Samson Tires? #3
soundguy
I know this thread is 3+ years old but I was wondering how well the Samson tires are holding up / or held up. I have a set in my radar priced at $200.00 each. Other brands are upwards to $300 $400 each.
Thanks,
Kent
   / Samson Tires?
Thanks,
Kent
Kent:
I ended up buying the Sampson rear tires, and they are holding up just fine! I live in very rocky terrain, but the tractor does not see heavy use, although it's parked under a tree, so it does get a lot of sunlight on the tires. Hope that helps!
Regards,
Scott
   / Samson Tires? #5
Samson sells a lot of truck tires...
   / Samson Tires? #6
Thanks,
Kent
still fine. added a backhoe to that tractor now too!
   / Samson Tires? #7
Well the same place (Pep Boys) who quoted me $440 on the Firestone 8 ply tires found out that they can get the Samsonsn(4 ply) for $173.16 each.
With two new tires, tubes and mounting I will be out the door for less than $500.00
I almost went with the Firestone tires but at over twice the price I decided to go cheap for now. I'll drop my rims off tomorrow morning and have new tires by the end of the day.
My old tires are Firestone but I think they are only 4 ply.
Kent B.
   / Samson Tires? #8
Kent B.
Is that for front's or rears? I really need new front tires. I could "use" rear's but my current ones are filled with rimguard, and I don't know if I want to tackle that project!
   / Samson Tires? #9
Those prices are for the rear 11.2 x 24
I bought the Carlyle tires for the front already. I think that they were $ 90.00 plus tubes and mounting
"Neece" is the name of the heavy equipment shop with the HIGH prices. They are $100 over priced on everything.
One of my new front tires went flat a day after they were mounted. Pep-Boys replaced the tube for free... as they should.
Some of the work that they do is free anyway so I think that I will keep using them as much as possible.
   / Samson Tires? #10
fronts are generally less than 100$.. even tsc usually carries some..
2014 ATC TRAILER (A52472)
2014 ATC TRAILER...
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
1982 MACK RD685S HOTOILER (A52472)
1982 MACK RD685S...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
