Sagebrush Has to go. Whats the easiest way to clear 10 acres?
   / Sagebrush Has to go. Whats the easiest way to clear 10 acres? #31
It usually pops out of the ground pretty easily, the hardest part is how brittle the stock is, it likes to break. Good thing is it usually doesn't come back after fire or being broken completely off.
Thanks for the schooling. Now I understand why many are saying a grapple would do the trick.
   / Sagebrush Has to go. Whats the easiest way to clear 10 acres? #32
Sounds like sagebrush is a lot easier to eradicate than scotchbroom. Wish they had left it wherever it was originally found, along with Himalayan blackberries and a couple of other invasive species.
   / Sagebrush Has to go. Whats the easiest way to clear 10 acres? #33
Flail mower,
   / Sagebrush Has to go. Whats the easiest way to clear 10 acres? #34
Get a hay supplier to cut and bale it. Done with it. Use if for erosion control.
2008 KOBELCO SK210LC EXCAVATOR (A52707)
2008 KOBELCO...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2005 Ford F-150 Ext. Cab Pickup Truck (A55852)
2005 Ford F-150...
(2) 10000 LB DROP LEG TRAILER JACKS (A57192)
(2) 10000 LB DROP...
Case IH 685 (A53317)
KUBOTA ZG1235 ZERO TURN MOWER (A57192)
KUBOTA ZG1235 ZERO...
