Sagebrush Has to go. Whats the easiest way to clear 10 acres?
   / Sagebrush Has to go. Whats the easiest way to clear 10 acres? #31
It usually pops out of the ground pretty easily, the hardest part is how brittle the stock is, it likes to break. Good thing is it usually doesn't come back after fire or being broken completely off.
Thanks for the schooling. Now I understand why many are saying a grapple would do the trick.
   / Sagebrush Has to go. Whats the easiest way to clear 10 acres? #32
Sounds like sagebrush is a lot easier to eradicate than scotchbroom. Wish they had left it wherever it was originally found, along with Himalayan blackberries and a couple of other invasive species.
   / Sagebrush Has to go. Whats the easiest way to clear 10 acres? #33
Flail mower,
   / Sagebrush Has to go. Whats the easiest way to clear 10 acres? #34
Get a hay supplier to cut and bale it. Done with it. Use if for erosion control.
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A57193)
UNUSED FUTURE SB45...
2006 Ford F-750 Stellar 6620 6,000 LB 3 Ton Crane Mechanics Truck (A55852)
2006 Ford F-750...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
AGRI-X 5' ROTARY MOWER (A57192)
AGRI-X 5' ROTARY...
12-Ton Hydraulic Bottle Jack (A55852)
12-Ton Hydraulic...
