Safety tips
/ Safety tips #11
I read somewhere that the PTO at 540 rpm could wind up 420' of line in a minute or less so stand clear of it.
Also, when using the FEL always have something on the 3 pt to counterbalance the tractor. When using a rear implement you should also have something, usually the FEL to counterbalance the tractor as well.
Watch out for holes which could cause the tractor to roll over very quickly if the front wheel catches and the tractor is already tilted.
Approach steep hills head on, not sideways. If you must aproach sideways, go slowly and use 4 wheel drive as it may keep the tractor moving and prevent is from sliding sideways. Mow up and down hills and not sideways if they are steep. It doesn't take much of a tilt to make the tractor feel very unstable.
That's just my 2 cents worth. Enjoy the tractor.
/ Safety tips #12
Keep a fire ext and 1st aid kit on the tractor. Take a cell phone with you if you have one.. or 2-way radio.. or CB (ham radio if you are licensed.. etc.. ).. etc.
Soundguy
/ Safety tips #13
I read what someone said about making the highways safer; he said if we outlawed seatbelts and required that each car had a sharpened 12 inch spike protruding from the center of the steering wheel that highway deaths would be cut in half. His point was that the operator of the vehicle was the major determining factor in how safe a given car is. No seat belt and a spike would make the majority of people much safer drivers.
I would apply the same logic to tractors. The most important safety feature is the operator. Don't depend on safety features to protect you. Be afraid when you are on a tractor. It is inherently a very dangerous machine. I posted a year or two back when there was a thread about "seat time" that I conservatively estimate I have spent at least 10,000 hours in a tractor seat. I can only remember once or twice when I almost hurt myself. Once was very recently when the front wheel/axle picked up a one inch diamater limb that had been broken off with a sharp end left on it. The sharp end of the limb caught momentarily on my boot, forcing my foot back. It slipped off and went under the tractor. If it had caught just right, it could have severely cut me. I was lucky. I had mowed that area before and the limb wasn't there. It was in high grass that only gets mowed about every two years. I have no idea how the limb got there. The only way I could have avoided this was to have just not mowed in the area I was in. Mowing those areas are part of the reason I have a tractor. That is what I mean about inherently dangerous.
I sometimes do things that manufacturers and people on this board say never to do. For instance, when I am baling hay, I sometimes get off the tractor with the baler running at full operating speed. I need to be able to look in the throat of the baler, or look at the side of the baler to determine what is causing a feeding problem, or what may be making a different noise. I am always extremely careful not to get closer than about one and one-half times my height (approximately 6 feet) to any operating mechanism. I would never work on it, or make adjustments while it is running. I figure at that nine or ten foot distance, even if I trip and fall, I won't get in the mechanism. Some would say even that is dangerous. Maybe so, but it is one of the risks I am willing to take. I think if you have a constant awareness of the danger, then you won't become careless.
As for guards and warnings. I think most of them are put there as a CYA device for the manufacturers. I have jokingly said that more people have had strokes and heart attacks trying to grease a piece of equipment with some kind of guard making the fitting inaccessable than have been hurt by the lack of a guard. I would never send a hired driver out on a machine without all the guards and warning decals in place. If I am operating an older piece of machinery, or one where someone has removed a guard myself, I don't worry about it. I KNOW that pto can kill me, whether it has a guard or not. I ain't going to get close to it either way. I KNOW better than to walk under a lifted bucket on a FEL or tail gate on a baler. My baler has a supposed lock-out hydraulic mechanism that would prevent the tail gate from falling in case of hydraulic failure. I absolutely did not trust it. The only way I would go under that gate was with the lock-out engaged and somebody with me to call for help if I got caught.
Anyhow, I'm not downplaying the importance of warning decals and guards. What I'm saying is that the most important safety feature is between the operators ears. It is impossible to make machinery fool-proof because fools are so ingenious. Be careful.
/ Safety tips #14
Red level, Very good. There is no safety device in the world that can compare to an aware and cautious user.
I recall a poster of the OSHA approved cowboy. I don't recall all the safety equipment but it was on the order of sissy bars and a roll cage around the saddle, headlights, folding stairs, and all sorts of ridiculous "SAFETY" equipment with a automatic pooper scooper attached at the rear to clean up after the horse. I doubt the cowboy could have roped a stationery fence post or gotten close to a calf or done anything productive.
Manufacturers are aware that it is imposible to make farm equipment completely safe at a price users can deal with and they partially compensate with warning decals and disclaimers.
About the PTO, I have seen taped interviews of folks who have literally been wrapped up and slung around in a loop several times before getting loose (including a body part failing.) It was not a pretty sight to see a person that twisted out of shape and disabled for the rest of their life for a brief lapse of concentratioin.
Pat
/ Safety tips #15
Here at work several years ago they brought in a guy as part of a safety briefing. His arm had been caught in a PTO. His whole body was LITERALLY wrapped around it and it kept on running for awhile, flopping him around. The guy was a 3&1/2 amputee. Only had a partial stump left of one arm. Both legs gone and one arm gone at the torso.
Never got that image out of my mind and every single time I climb on the tractor I remember the image. I try hard to STAY a little scared when I'm around the tractor.
/ Safety tips #16
hobbit, that story scares the bejesus out of me, thanks for posting it and pushing my awareness level waaaaay up. :eek:
/ Safety tips #17
CQ, CQ, CQ... de N6AYR
Uh, yah... my Kubota dealer has a video library with all sorts of operating and safety info including interviews with mangled folks, including (I guess I am a chauvinist) a mangled lady which disturbed me. When I have to make an assessment regarding whether or not to do something under an implement or the tractor or even operation stuff, I fold in some remembrances from those videos before proceeding and sometimes a good jackstand is added or I find a better way even if it takes 90sec longer or whatever.
About the time I got my tractor a local resident (in 90's) was cleaning mulched grass out from under his brush hog when it fell, crushing him instantly. I definitely take precautions before getting under my BIG HEAVY brush hog.
Pat
/ Safety tips #18
Pat
That kinda sounds like the "Shake hands with Danger" educational series, only real.
/ Safety tips #20
Look under the dashboard for bee nest before you get on the tractor!!!!
Ask me how I know.Bzzzzzzzzzz
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
Kubota L3130 (A53317)
