Safety interlocks on BX24
/ Safety interlocks on BX24 #1
easternhunter
Charleston, WV
Kubota BX24
OK guys ... My apologies for the late and urgent request ... am chastened by having to ask!
I have what I think is a safety interlock switch not allowing my BX24 to start. Everything seems to work ... fuel pump ticks, glow plug shows working ... but will not spin the starter.
Have seen this before. Requires jiggling controls for such things as gear speed selector around until something changes and it starts.
Need the tractor to move snow ... way too much driveway to do by hand.
What do I need to know to start isolating the problem?
/ Safety interlocks on BX24 #2
I would look first at the forward-reverse pedal switch. I don't know how it works or where it is. Just that if you are off the running tractor and move the pedal, it dies.
Bruce
/ Safety interlocks on BX24 #3
PTO switch /lever must be in neutral, HST pedal must be in neutral position also some tractors require the transmission to be in neutral also. Check all these and if all are in neutral, then rock the HST pedal back and forth while holding the key in start position.
/ Safety interlocks on BX24 #4
Try rocking the HST pedal back and forth. If that doesn't work turn the key on and try jumping across the starter.
Thanks guys. Read the threads on non-starting BXs. I suspect the PTO ... will try it but now have to dig the tractor out first.
ROUND BALE HAY RING (A63291)
ROUND BALE HAY...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A61572)
2025 Kivel Fork...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2005 John Deere 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
