Safe way to raise a 30' pole
   / Safe way to raise a 30' pole #1
HappyOne
North Central OK
L5740HSTC
I want to stand one of those 30' aluminum light poles using my L4350. I know it can be done safely, but need some inspiration. The pole will attach to 4 lag bolts in concrete. It's not super heavy, around 10" at the base. I'll have a couple of helpers that can be on ropes.
   / Safe way to raise a 30' pole #3
How heavy is it?
I set some 20 electric poles with my L3400. I imagine they were heavier than your pole.
What I did was have the pole long ways in front of me. I got the FEL cutting edge under what is to be the top end. Then curled the bucket back and drove under the pole. The pole slid up and over the top lip of the bucket and back up and over the tractor. Once I got low enough on the pole, and with it resting on both the cutting edge and top lips of the bucket, I used HD ratchet straps and strapped the thing to the bucket. Now it was just a matter of raising and dumping the bucket and the pole was vertical:thumbsup:
Might not work since your pole is soo much longer, but if it isnt heavy it will work. You just have to get low enough on the pole so that when you raise the FEL and curl down, you can get it to vertical before the base hits the ground. For a 30' pole, that will be well over center, but if it isnt heavy.........
   / Safe way to raise a 30' pole #4
I am presuming you have a front loader. What I do is bolt an extension pole to my loader so that I can get some extra height, lets say 16' overall at the end of the pole with the bucket raised to the max height. Then I assemble the light (lantern, bulbs, cord, finiale).
Next, I add weights to the base of the light pole so that when its picked up at the 15' mark, the pole would hang almost vertical from this new c. of. g. Leave the extra foot to reach over the baseplate bolts.
When you raise the loader with a strap at the new c. of. g. (light + pole + added weight(s)), the assembly should want to travel with the base end on the ground at all times. lift it up and you can place the base on its foundation. You ought to be able to do this just by yourself since the tractor carries 99.99% of the weight. Bolt it up and remove the added weight(s). Strapped on suitcase weights work for me.
Having a smooth loader valve controller makes this easy because you can raise or drop the load very slowly. If you are going to have to travel some distance to the pole's new location use a rope to hold onto one end. They tend to want to swing around as you move.
Thanks for the great ideas. Yes I do have a front loader, and the poles can be handled by two people. My bucket has a 4 holes in the side from a former bucket attached post hole digger. I might be able to tie it off there and just use the bucket to pivot it into place. Your ideas have given me some good inspiration.
   / Safe way to raise a 30' pole #6
Just one more reason I need a logging winch!
   / Safe way to raise a 30' pole #8
How about if you screwed a couple of pieces of 2X wood together to from a "V" and clamped or bolted that into your loader bucket. Go to the top end of the pole and put it in the V in the bucket. Put a strap or rope around the pole to keep it from falling backwards when you tip it up. Then drive the tractor forward raising the bucket and letting the pole slide down the bucket until the pole is vertical.
   / Safe way to raise a 30' pole #9
You asked for a "safe" way to do it. That would depend on how much space there will be between the final resting spot for the pole, and anything else of value.....
I did a 26' steel pole up against my house by anchoring the base and sliding/lifting the pole up between the "prongs" of my FEL forks. It couldn't go sideways because of the forks and would rest against the house in a premade bracket once it was vertical.
   / Safe way to raise a 30' pole #10
A safer way than freely lifting the pole would be to make a temporary hinge between the pole base and two of the mounting bolts in the concrete.
Then you can tilt it with equipment and/or manpower, with no danger of it swinging or flipping.
Bruce
STAINGLASS SHIP SCREEN (A58374)
STAINGLASS SHIP...
Quick Attach 84" Skid Steer Broom, S/N 103581, Asset# 73 (A59076)
Quick Attach 84"...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
LOT: (40 approx. ) Chain Link Fence Panels (A59076)
LOT: (40 approx. )...
INTERNATIONAL 5100 END WHEEL GRAIN DRILL (A52708)
INTERNATIONAL 5100...
