Safe to pull trailer???
/ Safe to pull trailer??? #1
coolbrze
VA
Kubota MX5800
I've got a Kubota MX5800 & also have a tandem axle 7k landscape / utility trailer that weighs 1,825 lbs. Can my MX safely pull this trailer up / down a gravel driveway w/ semi-steep hill? Worried about power to pull it up & braking going down...
/ Safe to pull trailer??? #2
What are you pulling on the trailer? That's a 60 HP tractor that weighs 3700 pounds. If the trailer has brakes, connect them up. If the tractor won't pull that trailer you probably need to get a new tractor.
/ Safe to pull trailer??? #3
Is the trailer loaded to capacity (7k) during this trip or is it empty? Use FWD as it will provide traction and will allow the rear brakes to apply to the front wheels for 4 wheel braking.
/ Safe to pull trailer??? #4
It's a tractor and a driveway, try it when the trailer is empty, drive slowly under nice dry conditions. Proceed with caution, only YOU know your pucker factor.
/ Safe to pull trailer??? #5
Tongue weight will be your friend till it gets to be to much and bends the drawbar.
I've pulled trailers up my driveway with the tractor that my pickup spun out trying to pull up with, with a Branson 8050 she does dress out at close to or a bit over 10,000#.
/ Safe to pull trailer??? #6
I'm seeing the trailer as empty given the information provided, in which case you can pull that trailer all day and twice on Sunday.
/ Safe to pull trailer??? #7
Try it,that's how we found out.
/ Safe to pull trailer??? #8
You should have no issues. Use 4wd because that will allow your front tires to aid in braking
Thanks guys, tractor is almost always in 4wd here in the mountains. The 1,825 lbs. is the trailers empty weight. Trailer has brakes but my MX doesn't have a 7 pin connector. Wanted to do a hay ride w/ the kiddos but will do a few dry runs 1st & see how it does. Do drawbars bend that easy? Seems like that sucker is SOLID.
/ Safe to pull trailer??? #10
Simple to add break controller if you are concerned, and if tractor has no brake lights or 7 pin connector, just add universal brake light switch to brake linkages and appropriate wiring...
/ Safe to pull trailer??? #11
Or get a thumb button hand held switch and connect that to the brake controller. It won't know the difference between a switch or a brake light to provide voltage.
Thanks all. Didn't hook any brakes but she pulled the trailer just fine. Wasn't sure about the hill on my gravel driveway but it wasn't a problem. Did an empty test run 1st, then loaded a 1,000 lb log on her to make sure & all was good!
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2022 John Deere RD40F Draper Head (A63111)
2022 John Deere...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
