SAE Cat.1 specs...
/ SAE Cat.1 specs... #1
jdl
Bronze Member
Trying to save myself a few bucks and build some of my own attachments. Currently in the process of building a box blade and was wondering if there is a standard measurement for the mounting pin locations. Does it make a difference for "limited cat.1 vs SAE cat.1"? I measured my snowblower and tiller and they are both different. Thank you.
/ SAE Cat.1 specs... #2
Unless you got free metal.. i don't see how you can come out building a single unit.
Yes.. measurement does make a difference.. if you have a full cat 1 tractor.. stick to the cat 1 pin and dimensions.
soundguy
Yes, I do have some free steel and like to do my own welding. Where do you find the dimensions?
/ SAE Cat.1 specs... #4
one place...
TractorData.com - Three-Point Hitch
Doesn't tell the distance to the top link but I believe cat 1 in 14 3/4 inches and cat II is 15 inches. ('nother edit) 18 inches on cat 1. The previous measurements are for a quick hitch hook bar is you have one.
Someone here posted a diagram, or a link to one but I can't find it just yet.
edit. lots of variation in cat 1. hopefully everyone will standardize some day
/ SAE Cat.1 specs... #5
Ditto on the variations in Cat 1. The BX24 is supposed to be Cat 1 but the top link sold at tractor supply as a Cat 1 is about 3-5 inches longer than Kubota's top link:( The Cat 0 at TSC is about the right length but the pin holes are too small.......to get the right size pin holes you buy the too long one and cut 3 inches or so out of the middle and weld it back together BTDT;)
Thanks everyone for your responses, that's why this is such a great site lots of helpful info.
Awesome, thanks KennyD.
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
2011 FORD CROWN VICTORIA POLICE CAR (A66091)
2011 FORD CROWN...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
PORTA POTTY (A67714)
