sae 80 oil?
   / sae 80 oil? #1
lostcause
Maine
anyone seen anywhere that sells this? everything now is a multi-grade 80w-90 or synthetic 75w-90. i just want a straight 80 for the transmission/final drive in an old car i'm buying. i only need a couple of quarts.
i've seen some motorcycle/atv documentation that mentions 80 weight oil. i suppose if there's nothing left in the automotive industry i can look to cycles.
   / sae 80 oil? #2
Why not use 75W-90? I presume it is a manual transmission and the only difference will be slightly thinner when cold and slightly thicker when hot. I have not seen 80w at any cycle shops but then my bikes also call for 75w-90.
   / sae 80 oil?
it will never have to deal with cold, so i don't need the benefit of the winter viscosity, even though it is nearly the same. it's more the other end of the spectrum i'm concerned with. i really don't want to subject the drive train to any thicker oil than necessary. we're talking 65hp @ 4700rpm if i remember correctly. i'd prefer to go with what it had originally, if possible.
   / sae 80 oil? #4
I'd check with the people over at bob is the oil guy website about where to find straight 80 wt gear oil. If it was mine, I'd run a 75w90 synthetic.
   / sae 80 oil? #5
you can still get 90wt gl1 at napa i think 65-201 is the 1g jug number.. and 65-205 is the 5g pail.
soundguy
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
American G-Model Pump Jack (A55218)
American G-Model...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
