Sad old barn
/ Sad old barn
Wen, that sounds like the ticket. I have a couple of questions though if you don't mind. What's an R panel configuration? What do you mean "string it with chicken wire"? And by "start from scratch for 50% more" do you mean you can do a whole new building with a steel frame for 50% more?
/ Sad old barn #15
Around here there are quite a few houses that use coarse chipboard for exterior siding on houses. It's just nailed on, 1" boards are nailed over the seams, and the whole thing is painted. Most people that have it say they're going to get around to the siding some time, but the chipboard seems pretty permanent. Don't know if it's cheaper than galvalume metal.
/ Sad old barn #16
R Panel is the name of the 3 ft panels designed to span 6 ft between girts. It is available from large metal building companies such as Mueller, Whirlwind, and Metal Mart, although Metal Mart does not use the standard R panel and they are higher in price.
Cover the structure with 2 inch chicken wire first, then use vinyl covered roll insulation and then put on the metal. Gives a nice insulated building that looks good inside and requires no sheetrock or other materials to keep the insulation in place.
Yes, they will quote the entire building shipped to your site or just the metal panels. I was pleasently surprised that the metal buildings are much less expensive than all other types and very durable. You should be able to reach Whirlwind at (214)241-0710 (The last digit could be 8 or 9). Their home office is in Houston Texas, but they have sales offices in several major cities.
As an example, I built my barn 5 years ago. The cost of the entire structure and metal panels for a 50x90 barn 12 ft high was $12,263 not including roof vents, insulation, overhead door,foundation, or erection. $12/sq ft is pretty hard to beat! /w3tcompact/icons/smile.gif
/ Sad old barn #17
Dfelgar.
By the sounds if you were to repair the barn from top to bottom your summer going to be busy.
Maybe its time to start over with a new barn,and it will last your life time plus.
Have you check into the metal barns or sheds?
They good looking and can take a lot of weather.
Take care and stay safe.
Thomas..NH
1965 Fontaine PS2824SP 28FT 15 Ton S/A Flatbed Trailer (A59230)
1965 Fontaine...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
2008 CATERPILLAR...
2025 42in. Hydraulic Auger Mini Skid Steer Attachment (A59228)
2025 42in...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
Diesel Fuel Transfer Tank (A59230)
Diesel Fuel...
