Sabre Samurai Cutter attachment
/ Sabre Samurai Cutter attachment #41
Louie, look on the picture; those holes are to LOCK OUT the breakaway feature.
Thanks Steve - I wondered if those were for some kind of breakable pins, or something. I have my original bracket to use if I don't want the break-away feature. There appears to be additional holes to lock in the 90ー position.
/ Sabre Samurai Cutter attachment #42
Just to make things easier, I put Pioneer couplings on the unit, so at least I am not struggling with the hoses in addition to the mount and sickle.
I see modest hose and worm clamps in the picture. It gives me hope that this just might work on my Steiner with very limited hydraulic power.
/ Sabre Samurai Cutter attachment #44
I implemented your suggestion and installed fasteners onto the sickle bar. Thanks!
I use 1/4 inch hoses with flow restrictors to slow down the tooth speed.
/ Sabre Samurai Cutter attachment #45
I would be tickled pink if I could use this on my Steiner.
Given the modest flow requirements, I should have gone smaller on hoses and fittings. I too use a flow control. If I had used smaller hoses and fittings, the weight might not have been a factor requiring couplers.
PLEASE report your experience with the knives.
/ Sabre Samurai Cutter attachment #46
Old thread, but any updates? This still seems to be the only semi affordable tool to trim trails, road sides, and banks. I hate toys though, and this seems like it might be a bit light duty. I have bamboo next to my driveway, and would love to be able to keep it at bay during the Summer. I too would love to run it on my old Steiner, and / or my loader tractor.
It seems like salvaging a heavy duty old sickle mower and adding a hydraulic motor (easier said than down in I’m sure) may yield a more heavy duty unit?
/ Sabre Samurai Cutter attachment #47
I've been kicking the idea of a fork attachment style trailblazer attachment for several months. I have no experience with either, but this 'seems' like it may be heavier duty. TRAILBLAZER-HD for TB-2020 – STOUT DESIGNS, LLC
Runs on it's own lawn mower engine, so no hydraulic mods to worry about.
I don't have a cab, is falling debris a concern I should be worried about?
/ Sabre Samurai Cutter attachment #48
I have one set of remotes on the rear of my tractor. There is a lever for them next to the seat. Could I use these to power the Samurai sickle mower?
/ Sabre Samurai Cutter attachment #49
That's what I did on my B26 when I first got the samurai and it worked just fine but was a pain to connect and run the hoses up front so I could see what I was doing. I also used the RPM's of the motor to control the speed of the cutters. I later added forward remotes and connecting it was a lot easier. I now use a 7 foot sickle bar on front of my L45 so the little samurai has just sit in my shed for a couple years.
/ Sabre Samurai Cutter attachment #50
I'd be interested in the details of the 7' sickle bar, and since we're both in AL, might even be interested in the unused samurai?
/ Sabre Samurai Cutter attachment #51
the 7 footer is heavy I keep my drive clear with it was using the samurai for that task.
