Comparison Sa424
   / Sa424 #1
Rutman
Bostic, NC
Yanmar sa424
You guys that own a bush hog.
What size you running?
4 or 5 ft.
Wondering if it’ll run a 5 footer ok.
   / Sa424 #2
You could quite reasonably run either, but as is often the case the larger implement may require you to just go a little slower, take a little more time, if you're getting bogged down.
   / Sa424 #3
4 or 5 ft.
I run a 5' on mine. Handles it like a breeze, but I'm usually just cutting grass not brush so much. Field was about 18"-24" tall when I mowed the other day.
   / Sa424 #4
Yes it will handle a 5ft. I went with a heavier duty 4ft instead, so less bogging while I'm cutting trails with saplings and weeds/brush up to 8ft high. 5ft is fine for flat fields of weeds. Plus the smaller size makes it easier to navigate the woods
   / Sa424 #5
Not to hi-jack the thread, somewhat along the lines of the what the OP posted though. Have any of you pulled a 5' disk or 5' tiller with your SA? Would it handle either?
   / Sa424 #6
I think it would pull a 5' disk easily enough. A 5' tiller might be a bit much, depending on soil type and depth. If I ever get one for mine I'll probably get a 54" - just enough to cover the tire tracks
   / Sa424 #7
I run a 60" Yanmar/Woods tiller behind my SA424 no issues with it at all.
Issue with the disk would be maintaining traction and working depth versus soil type and trash levels. I only have disc experience with implements far too heavy to lift with the SA and thus I am uncertain how to translate my experience with disc narrows to implements of a scale suitable for the SA424
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2008 John Deere 6330 Premium with Trebro Sod Harvester (A52128)
2008 John Deere...
2008 International 4400 (A50323)
2008 International...
2002 International 9200i Truck (A52128)
2002 International...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
