SA424 with skid steer quick attach
/ SA424 with skid steer quick attach #21
Thanks! Below is a sequence of photos showing the diff lock linkage, which goes aft from the pedal, up over the transmission to the right side, and down into the differential. It sure is a lot of levers, rods, springs, and tubes! Not as efficient as the custom lever that sa324owner built, but probably what most people will want:
/ SA424 with skid steer quick attach #22
Awesome! Thank you for those details and pictures!
/ SA424 with skid steer quick attach #23
My tractor (2019 build) has that same diff lock lever/pedal. It has gotten me unstuck more than once so I’m happy to have it, but I’ll confess to more than once pressing on the 4WD selector instead by mistake :(
If I was designing this from scratch I’d put the diff lock and brake on separate pedals on the left side. I don’t understand why they make it effectively impossible to hold the brake and one of the go pedals at the same time. Too far apart to heel-toe like a sports car…
F-150 4WD (A63689)
F-150 4WD (A63689)
John Deere 6155R (A64126)
John Deere 6155R...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
