SA Series Oil Filter
/ SA Series Oil Filter #1
Lunchbag
Maryland
Yanmar SA324
I just got back from my Yanmar dealer after picking up engine oil and a filter for the 200 hr service on my SA324. After taking off the old filter I noticed the new one is larger. The dealership is now closed for the weekend. The filter threads and rubber gasket look identically sized, and I think there is space enough to fit the big filter on the tractor. Also, note the last 5 numbers of the filter part numbers are identical (-35170). See the photo. I think I will put it on, unless someone thinks that's a bad idea. Thanks.
/ SA Series Oil Filter #2
I wouldn't hesitate to use an OEM filter that was larger as long as the gasket size is the same.
Thanks, that's what I was thinking. However when I tried to put it on it didn't fit. It was too wide and interfered with the engine mount structure. I think I'll head to the auto parts store.
Well, bummer. I bought an STP filter that looked perfect, but the threads are not a match. I guess I'll get the correct Yanmar filter next week.
/ SA Series Oil Filter #5
That would bug me, particularly after draining the oil and all.
/ SA Series Oil Filter #6
That is the filter for the YT and YM tractors. The dealer probably grabbed the wrong one or the wrong one was packed in the kit.
I got the correct filter installed, and all is well. Thanks again.
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
7ft. Fork Extensions (A59228)
7ft. Fork...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
Peterbilt 377 Semi-Truck (A61306)
Peterbilt 377...
Traxmax 300 Stand-On Tracked Sod Installer (A59228)
Traxmax 300...
2015 FREIGHTLINER SPRINTER 2500 CARGO VAN (A59905)
2015 FREIGHTLINER...
