SA 425 Hydraulic Top Link info
   / SA 425 Hydraulic Top Link info
   / SA 425 Hydraulic Top Link info #32
Thanks to all for the info on this. I found that (perhaps since this thread started) Summit Hydraulics has a top-link kit that works pretty well. Much of what is outlined here is included in the kit. I put together a video of my install if you are interested. Some of this information may help others.
Two follow up things from this video.
1. The lower arms on Yanmars are long. As others have suggested, it is a good idea to get a slightly longer top-link.
2. I ended up with a small hydraulic leak as the body of the hydro unit is bigger than the standard link and it interfered with the power-and-beyond loop for my backhoe. Not an issue if you don't have a backhoe but something to navigate if you do. It walked loose the power-and-beyond fitting at the 90 which was easy to tighten back up.
   / SA 425 Hydraulic Top Link info #33
I ordered mine from Amazon...search here for the ones shown here. There are others also. These hose lengths are right for your 425 if you add a 90 degree elbow on the end that goes to the rear remotes.View attachment 785090 These come from the Netherlands and it only takes about 3 days for delivery. One thing to know...the fittings are the wrong size for the 425. I had to go to a local hydraulics business to get the correct ones. JUst take one from the rear remote box and a hose with you and get 2 males that fit the new hoses. Its cheaper than changing the females on the rear remotes. You'll have to get a thread adapter to go from a brittish to us thread (the large hex piece below the elbow) and an elbow. Once that's done it works perfectly. Tighten fittings very tight. Good luck
Hydraulic Top Link Cat. 1-1 with Locking Block 20 7/8” - 31 7/8” with 2 x Hose
Hey I know it’s been a while since you installed this but just wanna know if everything is still working well?
   / SA 425 Hydraulic Top Link info #34
If you are going to have hoses made up just shut the tractor off and run the loader valve to get the hydraulic pressure out of the system. Unscrew one of the rear remote female fittings and take it to the hydraulic shop with you. That's what I did to make sure they had the right fitting.
I made mine 10" longer than the ones that came with the hydraulic top link. They are nice and long but not so much that they are in the way.
I know this is not a recent post but I just received my SA425. I plan to get a hydraulic top link. Would you please clarify two points. I have never dealt with hydraulic fittings.
1) run the loader valve - just raise and lower the FEL with the engine off? Or the 3-point?
2) Unscrew one of the rear remote female fittings - this makes me nervous. Just use a crescent wrench?
Thank you
   / SA 425 Hydraulic Top Link info #35
Thank you
Either loader or 3pt. should take the pressure off of the system. Unscrew it with a crescent or box end or pipe wrench; nothing to hurt here. Just be sure not to allow any dirt to get in. Use a clean rag over it to keep bugs or dirt from getting in it.
   / SA 425 Hydraulic Top Link info #36
Thank you
   / SA 425 Hydraulic Top Link info #37
AD
Just reviewing this post and looking for clarification on what I need for a successful top link.
I know I'm looking for a 21 - 32" cylinder and I wonder if it would be simpler to just get a cylinder alone and then have a local shop make the correct length hoses and install the right quick connects.
Kind of surprises me that there isn't just a simple plug and play kit. I was quoted $700 to have a top link installed by the dealer, but that seems pretty steep.
Any advice would be appreciated.
   / SA 425 Hydraulic Top Link info #38
Are you sure that is the working length that would be best for you?
Look at the following link, get the asked for dimension, then find a unit that provides roughly an equal amount of adjustment based on that asked for dimension.
Good luck.
   / SA 425 Hydraulic Top Link info #39
I was just going by what several other people with the same tractor I have found to work for them.
   / SA 425 Hydraulic Top Link info #40
What works and what is ideal can very often be very very different.
Even the OEM tractor manufacturers do the same thing, provide links that (work) on several different models, but are far from being what should actually be there, ALL of them do it.
It takes less than 10 minutes to know for sure. ;)
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
