s650g Satoh Bison PTO issues
   / s650g Satoh Bison PTO issues #1
tigermu05
bloomingrose,wv
s650g Satoh Bison
Hello All,
I have a Satoh s650g. When I try to engage the PTO it doesn't want to work. Without depressing the clutch I can move the PTO engaging arm up and down without grinding or anything. Sometimes I can catch it just right and the PTO will engage, but you never knwo when that is. It worked yesterday and just didn't today. There was no event or anything that caused this to happen. Can anyone help? thanks
   / s650g Satoh Bison PTO issues #2
I don't have our Bison here to look at, but I seem to remember a roll pin on the pto lever. Perhaps it has sheared ? If not, then something has sheared internally. I've had to tear down a couple Gravely riders to fix sheared roll pins in the transmission. 4 hours of work and mess to replace a $1 roll pin.
Thanks for the info about the shear pins. Does anyone have a diagram of the pto setup. That would help me greatly when i go to tear it down.
   / s650g Satoh Bison PTO issues #4
Here are instructions from the repair manual and one extra diagram I have collected.
   / s650g Satoh Bison PTO issues #5
these old tractors do not have a live pto you have to depress your clutch to engage pto.
other wise you will wipe out your gears . there is an over running clutch you can put on your pto to keep inplement from over driving your tractor
1996 International Water Truck with a Caterpillar Engine (A55218)
1996 International...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
