s650g governor
/ s650g governor #1
avanbre
pinon hills, ca
satoh s650g
the governor was making loud clanking noise, took it apart and the only issue was the two bearings and a seal, bearings were 6200,6203 and the seal was a 16x30x8
applied industrial had the bearings and they had a 16x30x7 seal, cost about $18 . cleaned it all up and put it back together, fairly simple internal design ,
nice and quiet . it is a set of flyweights that push against a lever to make carb adjustments. i would not let the noise go to far, if it damages the shafts or housing not sure what you could do then.
/ s650g governor #2
This is good to know. Mine just quit. Fortunately, I just finished my landscape project; we are sodding on Fri.
This is my first post in several years. I bought this tractor about 4 years ago and have used it with a finish mower, to dig post holes and to move a mountain of dirt terracing with a box blade and rip shanks. Oh, I did have to put on new front tires this year.
Up to now, all I have done is points and plugs, replace radiator hoses, change the oil and filter, changed the hydraulic fluid and cleaned that filter, and it has performed flawlessly for me. Smokes a bit, but I can put up with that for sure considering all the service I have gotten out of it. Will take the governor off next week and go through it.
/ s650g governor #3
Took the governor apart today. Case is slightly damaged, but not beyond repair.
I don't know how the thing lasted as long as it did. No lube in there.
Hopefully I can get parts locally tomorrow, but if I can't there is always interweb.
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
7102 (A61567)
7102 (A61567)
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
NEW HOLLAND C227 SKID STEER (A64279)
NEW HOLLAND C227...
Atspower Mini Excavator (A60352)
Atspower Mini...
