S650 Servicing?
/ S650 Servicing? #1
GTransport
New Holland LS180
I am purchasing a 2012 Bobcat S650 with 2500 hours. It is at dealer, they 吐ully serviced it including ALL filters and engine oil. They do not have any service history on the machine so i asked them about replacing the chaincase oil, hydraulic fluid, coolant and a valve set. They told me the only time they change chaincase oil is if it becomes contaminated or a seal needs to be replaced. Hydraulic fluid he said they only do if the color becomes darker then its supposed to be. Does this sound true or should I make them do both? They dont want to cover the cost of a valve set, is this something people actually do every 1000 hours or only if it starts running rough? I would rather them not open up engine anyways if its not necessary. Thanks for any help!
/ S650 Servicing? #2
Coolant 2 or 5 years depending on whats used (long life?) The book should tell you how many hours to change the hyd oil, chaincase oil, Valves idk on that I have seen truck engines wrecked by people adjusting valves wrong , I also would not want the engine opened up.....
/ S650 Servicing?
Thanks for the reply, service manual states all those items at 1000 hour intervals. Im just wondering how many actually adjust the valves at that interval if its running smooth and not making any noise.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2022 Caterpillar 289D3 Rubber Track Skid Steer (A64047)
2022 Caterpillar...
2016 Chevrolet 2500 HD 4WD (A63118)
2016 Chevrolet...
Snatch & Grab Tow Truck Bed (A64047)
Snatch & Grab Tow...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2018 FREIGHTLINER CASCADIA SLEEPER TANDEM AXLE  6X4 TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
