S570 pump help
   / S570 pump help #1
sundown57
taunton ma
bobcat
i need to replace the injector pump on DOOSAN D24 I can not find any info on how to time it to put it back in. Any one know of a video or have info on it? thanks
   / S570 pump help #2
S570 is a Mitsubishi-Satoh compact tractor. Not sure what a D24 actually is.
   / S570 pump help #3
If u can post a pic of the inj pump, I can probably walk u thru it.. but I have to know what system I’m dealing with.
Or send a prvt msg.
   / S570 pump help
it is a bobcat S570 with a Doosan D24 engine
   / S570 pump help #5
It looks like it’s a common rail inj pump..
The timing is set at the factory with different keys in the drive shaft of the pump..
U r gonna need a puller to pop the gear off tho..
The reason those pumps fail is: bad supply pumps..& dirty filters..& running the tank to empty..to where it sucks up the crud at the bottom of the tank..
MOST manufacturers will NOT warranty a pump without purchasing a new supply pump also..
Good luck
2022 BOBCAT T595 SKID STEER (A52705)
2022 BOBCAT T595...
1838 (A51248)
1838 (A51248)
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
John Deere 853 20ft Corn Head (A55301)
John Deere 853...
