s1500?
/ s1500? #1
boxorox
jax fl
shibaura s1500/kuboto bx2200/
I just bought a shibaura that has s1500 on hood on the tag s15d 11494 lem754-11494 28ps 863 then 760426 on the block also on the block is lem754 1484cc any help would be appreciated as i want to buya manual but I dont know wich model I have / also I have one other question I cleaned my injectors and noticed at the pump only two outlets produced fuel should I rebuild the pump or is there an adjustment. thanks for any info as I am new to working on tractrs and have twe Im working on now.
/ s1500?
I just read thAT a fuel pump can loose prime I noticed two dipsticks on the pump one is empty is that fuel or some sort of hydrolic fluid
/ s1500? #3
From your description of your tractor, it sounds like you have a S1500 hood on a Shibaura SD3000. Search for SD3000 in Google and see if the images look similar.
/ s1500?
I belive your right although in austria I found one just like mine with s1500 on hood but all other things point to sd3000/ an update its running fine I prayed one night woke op turned it over and it cranked my pops said something came loose I think god gave mea hand either way I love this tractor its strong my pops has an kubota bx2200 with loader and mine has tons more power.thanks for the reply right now Im getting implements or building them.still need manual.
2019 Chevrolet Tahoe (A64194)
2019 Chevrolet...
2017 Ford F-250 Knapheide Service Truck (A64556)
2017 Ford F-250...
3097 (A63117)
3097 (A63117)
2003 Ford Winstar (A64557)
2003 Ford Winstar...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
