s-650 -g
/ s-650 -g #1
deputy175
nw pa
Satoh Bison
I am repairing my satoh piece by piece. The next project is the exhaust. Mine ends at the muffler. The entire end is rusted off. Has anyone found a good replacement muffler. Where is the correct place to run a tailpipe. Mine ends right under my left foot. This causes the exhaust to blow up all over the operator. Also I have found the oil pressure orange light comes on frequently. The oil level is good, and the tractor leaks very little oil. It doesnt appear to burn any either. Has anyone come across front wheelweights aftermarket for a 650 g. I CURRENTLY HAVE A 6 FT HD BACKBLADE, IS THIS TOO BIG FOR THIS TRACTOR???
/ s-650 -g #2
The oil light is coming on because there is a drop in oil pressure or the sensor is bad. Purchase an aftermarket oil pressure guage and switch so you can monitor the oil pressure. If it remains ok, the sensor was bad. If it fluctuates you may have an oil pump problem.
The muffler was mounted under the foot rest and had a short tail pipe on it. I have a replacement pipe and muffler that I have made locally. You might try that or email or call 1-800-609-5110. I have alot of replacement parts for your tractor,
The 6ft blade is ok for the tractor. Bill - satohparts.com
3147 (A63117)
3147 (A63117)
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2009 Wilson Hopper Bottom Trailer (A66285)
2009 Wilson Hopper...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
