S-370D Front differential knuckle housing
   / S-370D Front differential knuckle housing #1
jangulaallen
Columbia Falls, MT
2-370 4x4
Hi,
Bought a S370 Beaver and was going over it. I found one of the bolts snapped on the front differential to knuckle housing. There is about 1/8 to 1/4 gap between the two housings on the bottom. The top is touching. Both sides are about same. (see Pic)
I'll have to pull the knuckle assembly to get the broken boltout.
I assume they should be bolted up tight against each other?
   / S-370D Front differential knuckle housing #2
Yes they should be tight to each other...
   / S-370D Front differential knuckle housing #4
I would use new bolts also, good luck
I took it apart to drill out bolt. Dang bearing was out too. Both sides. Not really surprised being it was angled.
Have to find bearings and figure out how bearings goes in. From the looks of it, bearing is snap ring to shaft and shaft has to come in from the hub side.
   / S-370D Front differential knuckle housing #6
I think your gonna need a shop manual:)
   / S-370D Front differential knuckle housing #9
My new to me S370D had a similar issue, both sides had loose bolts, but none were broke. I tightened them all up pretty good, but I never checked for broken bearings. Was yours making any noises that you could hear from outside the housing or did you only notice it when you took it apart? Was everything driving good otherwise? I just pumped mine full of grease and dont really feel like pulling it all apart to check bearings, unless I know what to listen for and hear it.
I didn't hear any noise but I'm about half deaf and engine is quite loud.
I pulled it because I needed to drill out broken bolt. That side bearing was out so I pulled the other side to check too.
It's not hard to do. Better safe than sorry. If you break parts, they are getting hard to come by and expensive.
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2005 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A54313)
2005 FREIGHTLINER...
2008 New Holland L175 (A47477)
2008 New Holland...
