RZT 50 left hydro not responding well.
   / RZT 50 left hydro not responding well. #1
mastercraftka
Hondo Texas
1993 JD 6400 4wd
The right one is working fine but the left side leaks slightly and it seems to not respond well especially when cold. The tank has plenty of fluid. Any ideas. Can you rebuild those things?
   / RZT 50 left hydro not responding well. #2
Here's a couple threads I'd bookmarked
http://www.tractorbynet.com/forums/cub-cadet-tractors/128383-cub-cadet-rzt-50-hydrostatic.html
http://www.tractorbynet.com/forums/...ub-cadet-rzt50-hydrogear.html?highlight=RZT50
To save you some time on the first link, check out pages 4,5,9,10,11 -
Also, a loose drive belt will affect the LEFT side more than the right, due to geometry. Do a search under my user name in this forum only - somewhere I posted my experiences and a work-around for the square drive hole (you can't get to) for changing belts.
IF you can't find that post, let me know HERE - I'll see if I can either find it or re-post my fix... Steve
Just a quick response before i read and thanks by the way, but i did recently replace the drive belt which helped some but it was minimal.
   / RZT 50 left hydro not responding well. #4
Had a similar issue with the drive on my Huskquvarna ZTR but with no leaks. It was a loose bolt that holds the drive pulley on the spline of the hydraulic motor, causing that side to slip. Unfortunately by the time I found it the spline and pulley were ruined thus costing $800 cdn. I now check both drive pulleys every spring
   / RZT 50 left hydro not responding well. #5
Did you ever get your problem fixed? I have an RZT54 that recently had the same problem. I changed the hydro filters and fluid and now the mower is like new again! I would recommend trying this before you tear down anything.
I haven't done anything yet. Where is the filter located is there one on mine?
   / RZT 50 left hydro not responding well. #7
If you have zt2800 hydros like i do, there is one filter per pump inside of a little plastic cover that has to be removed. My covers were packed with dirt and grass.
So there is one on each hydro? Top? side? back?
   / RZT 50 left hydro not responding well. #9
On mine, each filter is on the outer side of each hydro towards the back.
   / RZT 50 left hydro not responding well. #10
Try to find out if you have EZT hydros or ZT-2800 hydros. I have no idea what an RZT50 has. I have an RZT54 with a 24 hp Kawasaki.
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
UNUSED FUTURE MINI SKID STEER SIDE SHIFT FORKS (A51244)
UNUSED FUTURE MINI...
2015 CATERPILLAR D6T XL CRAWLER DOZER (A51242)
2015 CATERPILLAR...
IH 470 Disk (A50515)
UNUSED FUTURE SKID STEER QUICK ATTACH BACKHOE ARM (A51244)
UNUSED FUTURE SKID...
