RZT 50 left hydro not responding well.
   / RZT 50 left hydro not responding well. #11
It looks to me if you have EZT hydros, there is no filter. I would still recommend a drain and refill. My RZT has a reservoir under the seat and each hydro had a fill plug on top. If you have an EZT, I am not sure if there is a drain plug. If not, you will have to remove the hydros and turn upside down to drain the oil. I used Castrol 20w50 in my hydros.
   / RZT 50 left hydro not responding well. #12
Old thread I know...I recently did some work on my RZT54 mower deck (baffle came loose and made contact with a blade, so I installed a new baffle, new blades, new deck belt)
Anyways, I decided I would replace the drive belt while the deck was off and noticed that all of the hydro fan blades were missing on my left ZT-2800 hydro.
I ordered a new fan (that was a pain since the ZT-2800 have multiple fan types/configurations) and plan to replace soon. Has anyone here replaced the fan on a ZT-2800 without removing the hydro?
I drilled a hole in the frame from above and there appears to be sufficient room to remove the pulley and blade without removing the hydro.
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A57024)
2006 Heil Tanker...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
1844 (A57192)
1844 (A57192)
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
USED (2) 7000 LB AXLES W/ BRAKES & 4" DROP (A57192)
USED (2) 7000 LB...
