RX7340 Side Lights Option
/ RX7340 Side Lights Option #1
YooperWolv
Sault Sainte Marie
None
I see Kioti has an option, Part Number: RXA216 called "CAB Side work lamp kit". Has anyone had this option installed on their RX7340, and can you tell me where they get mounted? I see the HX models have a spot near the back of the tractor where these lights could be installed, but there is nothing like that on the 7340.
/ RX7340 Side Lights Option #2
I found all the Kioti OEM lighting to be under-performing and swapped them out with Amazon aftermarket units. Maybe you could wire something up yourself and run it into a vacant switch slot inside the cabin ? Most probably less than 25% of the Kioti pricing and way better performing. Extra switches can be bought from the dealership.
17109SFL (A61569)
17109SFL (A61569)
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
STEPP SEALCOATING MACHINE (A59914)
STEPP SEALCOATING...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
