RX7320 CEL Solved
/ RX7320 CEL Solved #1
cutthroat
MO
Kioti RX7340PC
For future reference if someone else ever has a similar issue. Was having a issue where my CEL light would flash on and off intermittenly. Sometimes it would stay on solid for a few minutes but would then go off. Could turn tractor off and back on and would stay off for awhile again, and then start flashing on and off. Called dealer and they came out to diagnose. The codes being thrown indicated a bad DPF sensor (maybe DPF pressure sensor). Tech did some voltage testing and found that the sensor wasn't getting the expected 5 volts. He took off the ECU wiring harness where I guess the sensor connects to, sprayed some cleaner on the pins and reseated; sensor was then getting the correct volts. So appears issue was just a loose ECU wiring harness. Thanks!
-Craig
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63688)
2019 Cadillac XTS...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
31" Minin Excavator Bucket (A66285)
31" Minin...
