RX6010 motor failed @ 450 hours
Status
Not open for further replies.
   / RX6010 motor failed @ 450 hours #41
. On my own personal note I did contact Kioti with the issue that I was experiencing with a CEL and limp mode with my tractor. Not only did I get a call from Kioti's Rep, but I also got a call from my local dealer. He made some suggestions that I did try. The tractor somehow fixed itself. Now it has occurred again some 40 hour later and will be brought in for warranty work. I believe that the ECM is not working properly.
That's the type of response that I'd expect from a company like Kioti.
   / RX6010 motor failed @ 450 hours #42
That's the response to be expected from a reputable company like Kioti and others. If not received at first go, keep trying.
   / RX6010 motor failed @ 450 hours #43
To end the BS going on with Eric and Coobie about warranty work and a video of tree removal. That video was published on You Tube in October of this year. That was well after the time when Eric had problems with his tractor that Kioti refused to repair. On my own personal note I did contact Kioti with the issue that I was experiencing with a CEL and limp mode with my tractor. Not only did I get a call from Kioti's Rep, but I also got a call from my local dealer. He made some suggestions that I did try. The tractor somehow fixed itself. Now it has occurred again some 40 hour later and will be brought in for warranty work. I believe that the ECM is not working properly.
that ECM problem sounds like it's just a bad connection somewhere, do you store the tractor inside or outside? rain can rust the connections if they are steel. you could have copper connectors mating to tinned steel blades..
   / RX6010 motor failed @ 450 hours #44
Yes, this is always something to take into consideration. On the NXes the ECM/ECU is under the hood and toward (but not right next to) the firewall. Not likely going to see water hitting. But, condensation is always a possibility. That said, if anyone is going to experience problems from condensation it would be me, with 60" - 70" or rain per year (and tractor isn't stored under cover). I'd think that the dealer and or rep would think to look at it as such. Anyway.... let's keep on the OP's issue...
I'd offer to chip in some coin to help defray the costs of learning what the problem is.
   / RX6010 motor failed @ 450 hours #45
Eric, here's the video he is talking about in 2018. I've seen a lot more done with tractors than this by a John Deere owner. MinnesotaEric
- YouTube
Sadly, I see my case has again been edited out.
The video you linked to is now used as an example by Everything Attachments, the OEM of the grapple used in the video, as to how to knock over trees without straining the tractor or loader. And yes was published this fall 2018, three years after Kioti's warranty department arbitrarily decided to to honor my warranty based on the first two videos I had published using the tractor with a BXpanded Piranha Tooth Bar.
   / RX6010 motor failed @ 450 hours #46
The video you linked to is now used as an example of how to know over trees without straining the tractor or loader, and yes was published this fall 2018, three years after Kioti's warranty department arbitrarily decided to to honor my warranty based on the first two videos I had published using the tractor with a BXpanded Piranha Tooth Bar.
You have several typos in this post. You may want to re-read and edit to correct.
As for your posts being edited out.... if you have any questions, send a PM to the owners of TBN.
   / RX6010 motor failed @ 450 hours #47
I had a crankshaft break on a low hour Kawasaki Mule Diesel, albeit some ten years out of warranty. Kawasaki said NO, then I escalated it and they contributed to the repair. They provided the crank and I had to pay for labor and any sundry parts. Still expensive, but it helped.
It's always worth a try.
   / RX6010 motor failed @ 450 hours #48
Post that everything attachment video.Love to see it.
Status
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
FIMCO 200 GALLON FENCE ROW / CATTLE SPRAYER (A52708)
FIMCO 200 GALLON...
2019 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A58018)
2019 VOLVO...
Electric Horseless Carriage (A57453)
Electric Horseless...
