Ballast RV antifreeze to load my tires
   / RV antifreeze to load my tires #21
RV Anti-freeze weighs in at 8 lbs per gallon. Cacl and rimGaurd are close to 11 lbs per gallon. I had a set of 26/12/12 tires filled at a tire shop. It was $53 for 280 lbs of liquid. (180lbs each tire/rim on a bathroom scale) $25 minimum for each tire and did not count gallons, then 6% tax. It worked so well that I had the rears loaded on my new tractor (1026r) before it was delivered. I would not even consider iron weights in this application, the yellow ones are way more $/# than what you have listed.
   / RV antifreeze to load my tires #22
I looked at it but had questions. The website says makes 6 gallons but the bottle says 8 gallons, which is it? Then it says "as low as -30". I got the feeling that the level of freeze protection depends on how strong you mix it. I would like to see the instructions
Thats what I noticed as well, I am going to call them tommorow, It just seems odd that one little bottle will even make 6 gallons freeze proof to -30, I will let you know.
Mike
   / RV antifreeze to load my tires #23
i for sure think the freeze rating will be based on mix concentration.. etc.
soundguy
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
UNUSED SDLANCH SDLC1220-12' X 20' CARPORT (A57193)
UNUSED SDLANCH...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
UNUSED PABREAK METAL BEAR SHOOTING TARGET (A57193)
UNUSED PABREAK...
UNUSED PABREAK DB220 - 84" HYD DOZER BLADE (A57193)
UNUSED PABREAK...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A57192)
2015 MACK ELITE...
