Ballast RV antifreeze to load my tires
   / RV antifreeze to load my tires #21
RV Anti-freeze weighs in at 8 lbs per gallon. Cacl and rimGaurd are close to 11 lbs per gallon. I had a set of 26/12/12 tires filled at a tire shop. It was $53 for 280 lbs of liquid. (180lbs each tire/rim on a bathroom scale) $25 minimum for each tire and did not count gallons, then 6% tax. It worked so well that I had the rears loaded on my new tractor (1026r) before it was delivered. I would not even consider iron weights in this application, the yellow ones are way more $/# than what you have listed.
   / RV antifreeze to load my tires #22
I looked at it but had questions. The website says makes 6 gallons but the bottle says 8 gallons, which is it? Then it says "as low as -30". I got the feeling that the level of freeze protection depends on how strong you mix it. I would like to see the instructions
Thats what I noticed as well, I am going to call them tommorow, It just seems odd that one little bottle will even make 6 gallons freeze proof to -30, I will let you know.
Mike
   / RV antifreeze to load my tires #23
i for sure think the freeze rating will be based on mix concentration.. etc.
soundguy
UNUSED RAYTREE RMRB72 72" HYD POWER RAKE BUCKET (A57193)
UNUSED RAYTREE...
12' CONTAINER (A57193)
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
UNUSED FUTURE (100) PIECES OF 12'X3' GALVALUME (A57193)
UNUSED FUTURE...
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
