Thank you all.
I took off the inspection plate and the spring to the linkage was hung up on the slide mounted to the inside of the block. I oiled it up and cleaned it the best I could, changed the oil and gave it a try. It ran rough for a little, but did idle.........I shut it down, started it again and it seems to be just fine. Thank you guys, you're a big help.
Dave
