Oil & Fuel Running Sluggish
/ Running Sluggish #1
viper318
Mahindra 3325
I have changed the fuel filters and fuel. When i start it up and give it more gas, it starts to run sluggish and is putting out white smoke. Is there something i'm missing? Is the pump going bad? Can anyone help.
/ Running Sluggish #2
Check your fuel line for an air leak or maybe an obstruction due to being pinched.
larry
/ Running Sluggish
Thanks for the info. I have already taken all the fuel lines off and blow them out. All lines are good.
/ Running Sluggish
I blew the filter off and nothing didn't come off. Filter looked pretty clean. I have taken the main air line off to the air filter can and started it that way. Still nothing.
/ Running Sluggish #6
viper318, what type of gas engine?
/ Running Sluggish #7
Check and see what kind of fuel flow you have from the tank. Been alot of problems with debris in the tank screen.
/ Running Sluggish
Diesel.
/ Running Sluggish
Thanks for the suggestion civesnedfield. I will check the tank out to see if there is any trash.
/ Running Sluggish #10
Easiest way to tell on mine is to remve the filter then open the shut off valve. If you have a weak fuel stream then the strainer is clogged.
/ Running Sluggish
Thanks civesnedfield. I pulled the main line off comming from the tank and the shut off valve. The shut off valve was pluged. Thanks again. you save me alot of money. I never hire anyone to work on any of my stuff.
/ Running Sluggish #12
I had a similar problem, it was a hidden filter not listed any were, it sites on top of the sediment bowl INSIDE THE FUEL TANK. It took me two years to find it.
/ Running Sluggish #13
No problem. Been there done that. Just do be careful not to run it too long if that happens again. Due to the lack of fuel going thru the injector pump, there is also a lack of lubrication, (Diesel fuel also acts as a lubricant) it is possible to damage the pump. No I didn't do that but I know of someone that it happened to. Let's just say every thing turned out ok after he bought a new injector pump. :(
2020 CATERPILLAR 239D3 SKID STEER (A65053)
2020 CATERPILLAR...
John Deere Bird House (A64557)
John Deere Bird...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2018 TAKEUCHI TL8 SKID STEER (A65053)
2018 TAKEUCHI TL8...
