running rich
/ running rich #1
momark
I have a '63 Ford 4000 gas (172 ci). I pulled a plug the other day and it was dry, but sooty black. What is the best way to lean it out a little? It has a Marvel-Schebler carb on it. Is there anything else that could be contributing to this besides the carb? Also, what are the best plugs to use in this tractor? Thanks for any help you can give.
/ running rich #2
Timing? Also, what sort of "work" is it doing? Slow idling or light duty in HOT humid weather will cause rich condition. Weak spark? (look at entire ignition system) Air filter (all the way to carb)? Low compression?
/ running rich #3
Screw the main jet in about 1/8 turn and try that.. make sure it doesn't hesitate when you goose the throttle.
AL437 plugs will be good. They are 1 step hotter heat range than the oem h-10 plug specced for that tractor.
What FWJ said was right. Weak spark and blocked breather will also cause sooty plugs... ( clogged breather acts like choke.. enriches ).. Also.. a weak spark may have made the prev owner enrich the mix to make it fire. etc.
Clean up all electrical connections.. use metal core wires.. check points.. etc.. and all electricals.. including ignition switch.
Soundguy
/ running rich #4
Hi Momark,
In addition to what the other posters have suggested you might want to try a slightly hotter plug if your use on the tractor is light duty !
Example, my 49 Farmall suggests Champion D-15 plugs, but those plugs are for a working tractor not an occasional odd job :) Instead I use D-21 a hotter plug and dont get the fouling and carbon buildup. Just something for you to look into!
/ running rich #5
Thus my advice on al437 / ch h-12 .. vs the ch h10 normally specified.
Soundguy
/ running rich
Thanks for the responses, guys. Checking all those things out ought to keep me busy for a few minutes. Ha! Will definitely try the hotter plugs and adjusting the main jet, then will go from there.
mark
/ running rich #7
Soundguy
Mornin Chris,
Must of not had the old readin glasses on :)
/ running rich #8
Actually.. my post may not have even been there when you posted, even though you posted well after me..... I just noticed last night that I could make replies to a sub.. and they would not show up for minutes to hours. in fact.. when they did show up.. -many- other reples would also show up. Kinda like the the boards was 'sticking' or something. i was gonna go back and delete my message after I thought about it.. but I couldn't.. I went to bed before it showed back up!!
I'll take that one as a 'my bad'...
have a good day.
Soundguy
/ running rich #9
have a good day.
Soundguy
Yes Chris,
I have noticed that also at certain times :confused: Anyway I have a bad habit of not thoroughly reading the whole thread before I offer my 2 cents :eek:
And I have some memory problems at times, like yesterday when I somehow mixed up titanium and magnesium :eek: I have machined both of these materials in my 35 years in the trade but it just didnt register at that time :confused:
See what happens after 55 :)
/ running rich #10
scott_vt said:
Yes Chris,
I was going to comment on what you said, but I forgot what I was going to say..... What are we talking about?
Getting old is no fun, but it sure beats the alternative.
/ running rich #11
Yep.. Just today i drove up to the school where my wife works. We had lunch in one o fthe classrooms with another teacher that is a friend of hers. They both took great delight when i had to look over my glasses to read some fine print on a bottle... Gotta love that age thing... But as FWJ points out.. getting older is better than the alternative.
I probably should have looked to see if my post had showed up before making my 2nd reply to your post.. weird.. it's almost like the board wasn't synchornized or soemthing.. cause it all looks fine today.
( maybee it's a conspiracy!! )
Soundguy
scott_vt said:
Yes Chris,
/ running rich #13
Might have had to been an allis chalmers way back then!
Soundguy
/ running rich #15
So true...
Soundguy
Sakai SW354 (A60462)
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
