Running a grain auger with 4000 series
   / Running a grain auger with 4000 series #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
I was planning on putting the 4700 on a grain auger this fall but the only way I know to do it is by pass the seat saftey switch as the pto won't run unless you are in the seat. Is that most of you have done or is there another way.
   / Running a grain auger with 4000 series #3
I might be wrong here, but with my 3720, and a friends 4320, if you start the machine, put the parking brake on, machine in neutral, get off the seat and start the PTO, it will run.
   / Running a grain auger with 4000 series #4
Check your manual. There should be a procedure to make the PTO work with no operator on the seat. Mine is like Nmu98's
I tried it and as soon as I turned on the pto it died
   / Running a grain auger with 4000 series #6
On my 4110, after you raise the seat you pull the seat switch UP to operate the PTO.
   / Running a grain auger with 4000 series #7
How big of auger do you plan to run?
   / Running a grain auger with 4000 series #8
What does your manual say??
UNUSED JCT HYD BACKHOE DIGGER ARM (A54757)
UNUSED JCT HYD...
UNUSED FUTURE FT-ZWB MINI BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE...
UNUSED FUTURE RB66 - 66" ROCK BUCKET (A54757)
UNUSED FUTURE RB66...
1990 CASE 90XT SKID STEER (A52705)
1990 CASE 90XT...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55301)
2017 KINZE...
