Running a grain auger with 4000 series
   / Running a grain auger with 4000 series #1
deere755
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
I was planning on putting the 4700 on a grain auger this fall but the only way I know to do it is by pass the seat saftey switch as the pto won't run unless you are in the seat. Is that most of you have done or is there another way.
   / Running a grain auger with 4000 series #3
I might be wrong here, but with my 3720, and a friends 4320, if you start the machine, put the parking brake on, machine in neutral, get off the seat and start the PTO, it will run.
   / Running a grain auger with 4000 series #4
Check your manual. There should be a procedure to make the PTO work with no operator on the seat. Mine is like Nmu98's
I tried it and as soon as I turned on the pto it died
   / Running a grain auger with 4000 series #6
On my 4110, after you raise the seat you pull the seat switch UP to operate the PTO.
   / Running a grain auger with 4000 series #7
How big of auger do you plan to run?
   / Running a grain auger with 4000 series #8
What does your manual say??
Hydraulic Power Unit S/A Towable Pump (A55787)
Hydraulic Power...
2004 Chevrolet Silverado 2500HD Service Truck (A55788)
2004 Chevrolet...
2007 Hannay reels Hose Reel (A54865)
2007 Hannay reels...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
CATERPILLAR 259D3 SKID STEER (A52705)
CATERPILLAR 259D3...
