Run'd out of Diesel - B7800
   / Run'd out of Diesel - B7800 #1
Temp97
Western New York
The boy ran it out of go-go juice. I've heard the stories about having to bleed lines and not running so well afterwards. Anybody have any advice before we try to start it back up?? Hoping that it's a self bleeder and it takes care of it's self.
Thanks
   / Run'd out of Diesel - B7800 #2
By the time you get that started, I will bet that you will never let it run out again.
   / Run'd out of Diesel - B7800 #3
Should have a hand primer, add clean fuel, pump the primer till hard, crack one injector line , pump hand primer till you see fuel. tighten the line, should start. CAUTION, be sure the battery is fully charged , engine has to spin over 75 rpm to start.
RZ HIll
   / Run'd out of Diesel - B7800 #4
From the B7800 factory repair manual. Looks like not a problem.
   / Run'd out of Diesel - B7800 #5
That seems as simple as if it didn't even run out of gas.
   / Run'd out of Diesel - B7800 #7
If that diesel ran out of gas, there are a lot bigger problems to worry about :eek: :D
Actually, didn't there used to be tractors that you started with a gas engine, and once they were warmed up you switched over to a diesel engine to work with?
   / Run'd out of Diesel - B7800 #8
Yeah. A guy near me has one. It has one engine that uses dual fuels. You start it on gasoline and then switch to diesel after it's warmed up. I guess the trick is that you have to switch back to gasoline before you shut her down or you won't get her started the next time.
   / Run'd out of Diesel - B7800 #9
We had some like an H Farmall with a small gas tank and large kerosene fuel tank. Hot head and piston made that possible if guess. I think it may have had steel wheels but I was very small at the time.
I hope it's this simple. I'm giving it a try tonight. I'll keep ya posted. Actually I just found a You Tube video about how to bleed the lines. If when I fill it up and if it doesn't work I will try their method. It's attached if I did it right,,,,
http://www.youtube.com/watch?v=XJn2kDnWQPU
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
