Run time on generator
/ Run time on generator #11
must be an awfully small generator. Those 30# tanks can freeze up badly. I cant see 2 days on one. The neighbor has a champion dual fuel, and quite a few tanks. I need to ask him how long between tanks. Still way cleaner running than gas. Easier on spark plugs and oil also.
That was where I was going, it's NOT going to happen!
SR
/ Run time on generator #12
Have you actually tried to run your generator two full days on a 30lb tank of propane??
SR
I converted my Honda EU2000 to run on propane, and it gets just about 40 hours operation on a 30lb propane tank
/ Run time on generator #14
But a 2000 watt gen won’t help much. A refrigerator can take up to 1200 watts to start. Most people also have separate freezers, than throw in a well. I had a 5,000 watt unit before my current one. It did marginal. Ran refer and freezer, some lights. Turn on microwave and lights dimmed.
/ Run time on generator #15
I have an EU2000, and it IS very fuel efficient, but you can't run much of a home on it either... Also, a generator has even less output when on propane, which limits the 2000 even more.
The OP was talking about a 5k genset on half load... Also, bigger generators have more problems on propane in the cold than in warm weather...
/ Run time on generator #16
i had one of those nifty patio heaters that run on a bbq style can of propane. when tank got about 1/2 empty on a cold day, flame went out. tank had frozen. whole house generators require a minimum 250 gal tank size to prevent this. my unit is 1000 gal buried tank. when living in north idaho, cant be too careful
/ Run time on generator #17
I brought the Hobart Champion Elite back from the ranch on Friday and so far we have been on generator power from it for about 37 hours. We have a 3300 foot house with lots of windows and Texas quality insulation and we ran lights, tv, two gas furnaces, 1100 watt space heater in the garage, pretty much everything but the electric oven, and it used about a gallon of gas an hour.
/ Run time on generator #18
Not gonna get into mine bigger den yers crapsling, just gonna point out 3600 rpm machine gonna be gas hog and pure he!! on lube oil cause oil in crankcase is half of engine cooling.
Sit de dang propane can in front of machine exhaust and get some value out of all de waste heat machine makes from fuel you paid for.
(removed) still runnin 1952 Onan CCK generator dat turns 1800 rpm. Burns about 3/4 gallon gas an hour and gets topdown oilchange every 24 hours running. Changed out fuel pump long time back to prevent MTBE gas passing thru Onan diaphram into oil. Happy machine and it knows 1951 Kohler 4 cylinder sitting in trailer waiting if CCK dies. Bought it a new battery dis fall.
Got Coleman spodabe 4500 watt in van fer portable use wid electric start. Coleman get 8 hour oil change and uses near twice gas per hour of Onan 7500 watt. Coleman won't last de hours Onan already has. 3600 rpm.
Come warm time both machines getting LED volt/amp meters fer to entertain me.
/ Run time on generator #19
Said (removed)"
"Come warm time both machines getting LED volt/amp meters fer to entertain me."
I also found them on Ali Baba @ very reasonable cost.
Came c/w with amp pick up coil: reads Volts, Amps and Hertz.
Plan is to install on main power panel.
/ Run time on generator #20
Frequency meter is the critical reading. If freq drops to low or spikes too high you start to roast things, especially electronics. Most generators accomplish this by having a volt meter. All 3 is better. I installed a 200A/100mV shunt and voltage/frequency transducer. I use a 1/8 din panel meter that reads all 3 in a rolling display.
2022 Kubota SVL97-2 (A60462)
2022 Kubota...
Toro z turn (A56859)
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
1995 HEIL  ALUMINUM TANKER TRAILER (A60736)
1995 HEIL...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
