Rubber Track replacement
/ Rubber Track replacement #1
polloloco911
John Deere 27D
Just bought a new track for my JD 27D (2009)
just don't know how to replace it.
Any info can help.
A mechanic talks about the grease valve in the side.
But not to sure.
/ Rubber Track replacement #2
I wonder if the grease valve he was talking about is the way they use to keep the tracks tight as they wear? If so it would make sense to relieve the pressure to replace the tracks.
/ Rubber Track replacement #3
Absolutely, correct. Remove the grease fitting from the tensioner. Collapse the tensioner piston and wrestle the track off. It is easier if you can get your machine 8-10 inches off of the ground. Good luck.
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
Truck Tool Box (A65640)
Truck Tool Box...
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
