RTVX900 diesel - Oil filter question Help, please!
   / RTVX900 diesel - Oil filter question Help, please! #1
Bigfoot62
W. Central Louisiana
JD 5090M; JD 5085M; JD 5083E; NH TN70A; Ford 2600
I have a 2018 Kubota RTVX900 Diesel. It has just over 50 hours on it, and I was going to do the first oil change. The filter that the dealer sold me is a larger diameter than the factory filter. The new one is about a 3" dia. The old one is 2.5" or less. (I didn't take it off yet) The problem with the larger oil filter is, there is a (maybe coolant) hose right above it, and I don't think that the bigger filter will fit. The OEM filter looks like it is already touching the hose.
Has anyone else had this issue?
TIA
   / RTVX900 diesel - Oil filter question Help, please! #2
I have a 2014 and have only used amsoil filters, but you are right that hose does touch it. The amsoil filter was the same size as the original one I took off. Amsoil pn# EAOM103
   / RTVX900 diesel - Oil filter question Help, please! #3
Sounds to me like the dealer looked it up wrong. Usually upsized filters are longer not wider. But if you are after a standard filter, it should match the OEM one exactly.
   / RTVX900 diesel - Oil filter question Help, please! #5
If you still have the box, or receipt that pn# should be HH150-32430
   / RTVX900 diesel - Oil filter question Help, please! #6
Is this the part number HH150-32430 Oil Filter?
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
Informational Lot - Financing (A57024)
Informational Lot...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
