RTVX900 diesel - Oil filter question Help, please!
   / RTVX900 diesel - Oil filter question Help, please! #1
Bigfoot62
W. Central Louisiana
JD 5090M; JD 5085M; JD 5083E; NH TN70A; Ford 2600
I have a 2018 Kubota RTVX900 Diesel. It has just over 50 hours on it, and I was going to do the first oil change. The filter that the dealer sold me is a larger diameter than the factory filter. The new one is about a 3" dia. The old one is 2.5" or less. (I didn't take it off yet) The problem with the larger oil filter is, there is a (maybe coolant) hose right above it, and I don't think that the bigger filter will fit. The OEM filter looks like it is already touching the hose.
Has anyone else had this issue?
TIA
   / RTVX900 diesel - Oil filter question Help, please! #2
I have a 2014 and have only used amsoil filters, but you are right that hose does touch it. The amsoil filter was the same size as the original one I took off. Amsoil pn# EAOM103
   / RTVX900 diesel - Oil filter question Help, please! #3
Sounds to me like the dealer looked it up wrong. Usually upsized filters are longer not wider. But if you are after a standard filter, it should match the OEM one exactly.
   / RTVX900 diesel - Oil filter question Help, please! #5
If you still have the box, or receipt that pn# should be HH150-32430
   / RTVX900 diesel - Oil filter question Help, please! #6
Is this the part number HH150-32430 Oil Filter?
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
183 (A52705)
183 (A52705)
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
