RTV900 will not move at first
/ RTV900 will not move at first #1
Alfred567
Buckhannon,W.Va.
Kubota
I have an RTV900 that will not move in H or M when you first give it throttle. Then it will take off all of a sudden and run well in all gears.
It will always take off in L or R just fine. I got this one used and it had some pretty rough treatment judging from the oil I took out of the trans.
Everything has been changed.
I also have one I got new in 07 and have never had any problems with. This kinda has me stumped. I wanted this in the ATV/UTV section but didn't know how to do it. Hope I am not stepping on anyones toes.
Al
/ RTV900 will not move at first #2
Do these have a centrifugal clutch like we had on snowmobiles when I was a kid? If so, sounds like the wedges need some lube.
Sent from my iPhone using TractorByNet
/ RTV900 will not move at first #4
yes super UDT2 ONLY. Regular UDT and cheap hydraulic oil does not play well with HST's and definitely not the RTV HST's. Beyond that, make sure the filters are fresh and correct. Then last step is to check the HST charge pressure.
The older 900's were a little slow to react to throttle input. Just the way that they came from the factory.
2015 MACK GRANITE GU713 T/A DUMP TRUCK (A59823)
2015 MACK GRANITE...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
New Holland WorkMaster 37 (A53317)
New Holland...
Iranch IRMC High End Massage Chair (A60463)
Iranch IRMC High...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
