JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,032
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
At least with my BX2200 the insufficient voltage at the solenoid primary was the culprit (and sounds like it was with your starter issues too.)In replying, I meant to mention your statement and expand a little - then forgot. The OP'S problem description just sounds SOoo much like what I went through with starters, I can't imagine the relay won't fix his problem.
Hopefully he gets it straightened out.
When that is the problem, the starter or solenoid or one of the relays prior to all that will make some clicking noises but the engine will not turn. In OTHER kinds of issues (e.g. like my B2150 where I have to whack the starter some once in while to get it to turnover there IS NO NOISE at all. ) So we just don't know.
The OP's problem might not be the low voltage getting to the solenoid but something else instead. That's why I suggested he try a battery charger (normally putting around 13.8v on the battery terminals) to see if it would then start. If it does that would confirm he has the "low voltage at the solenoid" type of issue. [And using the battery charger is to get the higher voltage, NOT implying anything wrong with the battery at all.] If the charger does NOT cause it to start, then he has some other kind of issue. OP has not mentioned whether he gets any kind of noise when trying to start and it fails (or not.) He has had 2 starters on and off multiple times and has to be frustrated big time by now. Let's hope he has the "low primary side voltage to the solenoid" type of problem because that is easy to fix and relatively cheap. However, with no mention of the noise when trying to start I fear it is some other problem.
