RTV900 front diff lock
/ RTV900 front diff lock #1
Little Mule
Anybody know of a way to install a diff lock(er) into the front end of a RTV900? Our unit (on tracks) stops going uphill when one of the front corners is off the ground. Extreme I know but there's nothing like pushing the boundaries!! As an aside would chnaging the oil to a thicker grade give a slower reaction? i.e. ****** the easy of track/wheel spin?
/ RTV900 front diff lock #2
have you ever tried to puch down the brake just a little bit?i know on my hpx and 99%of the 4 wheelers with limited slip front difs it works good in locking up the front end when needed.all it does is it fools the spinning front tire into thinkin it's in a bind and it transfers the force to the other tire.
/ RTV900 front diff lock #3
good advice!
/ RTV900 front diff lock #4
you can also install spacers into the wave lock washer springs (I am assuming thats what is used), or just stronger springs
/ RTV900 front diff lock #5
i really woudn't go into the front dif to manually lock it the limited slip is a really good thing to have because if your spinnin them tires and they bind up it will send the force to the other tire instead of snappin an axle or u-joint. now you still have a chance of snappin something but it's alot less likely to happen with the front unlocked .i prefer to keep my rhino's front end unlocked i very seldome use the front locker and i go into some deep gooy mud.
2022 EZ-GO ELITE...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A67147)
2018 INTERNATIONAL...
RHINO SE10 BATWING/DITCH BANK MOWER (A63276)
RHINO SE10...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
2022 EZ-GO ELITE...
