rtv500 bed lift
   / rtv500 bed lift #1
b-rad-g
I am looking for a hydraulic bed lift kit for my rtv500. Does any one make a good one?
   / rtv500 bed lift #2
we make a bedlift for the RTV500 see linked post here it is not hydraulic. I know of no other companies that makes a hydraulic one. Part of the problem with using a hydraulic bed lift on the RTV500 is tying into its hydraulic system. Any questions call me.
   / rtv500 bed lift #3
B,
Call Dan's Tractor in Battleground WA - 360-687-3000. Speak with Skip or Bill - they have a kit which is electromechanical, as on snowblower chute angle controls.
I don't know the cost.
Good luck!
   / rtv500 bed lift
How do the electric ones work? How much do they lift? how do they hold up to the weather etc. Is one better than another? Any feed back from someone who has one would be a great help.
   / rtv500 bed lift
I have found a true hydraulic bed lift kit for the rtv500. Neibur Implement in Hastings, MN. had one. I saw it and it is NICE!
Some new company is making them I think it is called Hydra-Lift Systems. They say it will lift over a 1000lbs.
   / rtv500 bed lift #7
Is this a electric over hydraulic system or is it run off of the transmission pressure. I have one of the electric ones from D & B it works great and lifts fast. The lift actuator on it is rated for 1000 pounds too but the rtv bed load has a max of a little over 440 pounds so I don't know what the point of going with a system heavy that this is. Also I looked into putting an electric hydraulic pump on the unit to run a hydraulic ram on it and they all draw over what the 40 amp alternator could put out and had concerns that if I over draw the alternator that the EFI wouldn't work right. Just my 2 cents. Watch what you buy.
   / rtv500 bed lift
It is electric over hydraulic and the unit is compact. It allows for thermal expansion and is load holding in both directions. I saw it go up and down and it is also fast. it is water submersible and easy to install. the switch has a thermal protected breaker in line.
I have done alot of home work on this one and I was about ready to build my own until I saw this one.
   / rtv500 bed lift #9
You can draw more than the alternator can put out for short periods without affecting the EFI. You would be drawing off the battery. My winch can draw 100 amps or more under load and I have not had any problems. Just make sure you have correct sized cables going directly to the battery.
   / rtv500 bed lift #10
Here is my automatic bed dump. She's having so much fun she works for free.
This does show you how well balanced the bed is.
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2015 KUBOTA M9960 LOT IDENTIFIER 199 (A53084)
2015 KUBOTA M9960...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
UNUSED AGT 46" EXCAVATOR HYD BRUSH FLAIL MOWER (A51248)
UNUSED AGT 46"...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
