RTV-X900 Wiring Question
   / RTV-X900 Wiring Question #1
TravisD
Westminster, MD
Kubota BX1870
New Kubota owner - Just picked up a BX1870, and an RTV-X900. I've been going over the RTV had noticed that there's some "extra" connectors in various places - presumably for factory options that my unit doesn't have. I'd love to know what these are for, and perhaps use them to facilitate future upgrades.
We ordered it with the VC5080 multiple accessory wiring harness, since we needed one of the harness options for the windshield wiper, and figured that leaving room for future upgrades made sense for the minimal cost difference. It looks like that option is basically the underhood fuse box, and perhaps the 4-switch panel?
Seems pretty straight forward - spare spade connectors, and add the appropriate fuse. I like that it includes the ground. It actually took me some time to notice this, since it's cleverly hidden in a velcro/vinyl "bag".
The first unknown connectors (A & B) are at the rear, near the transmission.
Connector "C" is under the hood:
"D" and "E" are also underhood:
"F" is tucked up by the front radiator grille.
I don't have any of the aux hydraulic control options or anything.
Thanks in advance for any pointers!
--Travis
   / RTV-X900 Wiring Question #2
I know the harness is installed for a speedometer. Connections close to the transmission, and at the instrument cluster. Harness for auxiliary lights. Some more that has slipped my mind at the moment.
I'm surprised the would wire for a speedo - this is a 2014 X-series so it has a digital Speedo built into the electronic dash already...
I'd love to be able to use pre-existing wiring to cleanly install some extra lights at some point. Guessing a workshop manual is the best investment?
   / RTV-X900 Wiring Question #4
Whoops I didn't see the X in front of the 900. You are right they do have a speedo. So I have to plead ignorance on the subject. One suggestion is get into the parts manual and run through the options and see which ones might need a wiring harness.
   / RTV-X900 Wiring Question #5
I too, have just picked up a new RTV-X900 and am wondering what the connectors are for. The ones in the rear are "hot" all the time as far as I can tell. I only did a quick look with my meter, and need to go back and check some more. I thought one would be for the optional back-up beeper, but it is not controlled by the shift lever going into reverse. I'd like to find a schematic of the entire machine. I'll post a link if I find one.
I hope to put in a pair of back-up lights and would like to use an existing harness - I can't imagine Kubota making different wiring harnesses for machines ordered with and without a beeper.
   / RTV-X900 Wiring Question #7
My RTV 400 has a long list of electrical options listed in the operators manual. Backup alarm, several light kits, strobe, speedo, ect. I would look there and see if you can guess the intended purpose. They put the wires there for some purpose.
   / RTV-X900 Wiring Question #8
The wires ( connections) by the back of the transmission are "hot" when the key switch is on. The reverse gear does not affect either of the connectors.
Apologies in advance if posting links to other forums is frowned upon here - but I did just stumble across some wiring diagrams posted over on NetTractorTalk.
RTV Wiring Diagrams - Net Tractor Talk
No clue how accurate these are - they're for an RTV-1100 - I'd hope that kubota keeps wiring somewhat consistent, but never know...
   / RTV-X900 Wiring Question #10
Thanks TravisD! I will try to print them up and study them. I am sure it will be helpful.
2003 JOHN DEERE 350D OFF ROAD DUMP (A51246)
2003 JOHN DEERE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
