RTV won't start
/ RTV won't start #1
Hootie
SW ARK
Kubota BX2200, Kubota ZD 221, Kubota Grand L 5030 HSTC, Kubota RTV, Polaris 500ATP
Not a mechanical genius here. Won't start, battery checks OK. Test light shows all good at hot terminal at starter and at flat lead at starter??
/ RTV won't start #2
well, might have to know a little more? does it crank over? do you have it in nuetral? might want to check all your fuses, is your glow plugs working? what are your temp, does it set outside? fuel might be jelled, just thought i would mention a couple things. maybe someone else will have better advice.
buck
/ RTV won't start #3
Is it cranking? If no crank, check the safety interlocks. If it is cranking, is there fuel?
jb
/ RTV won't start #4
It sounds to me like you are saying that the starter does not work. Most starters have power to them all the time, but it is not connected to the starter motor until the solenoid is energized by the start switch. If you have a neutral interlock switch on your shifter, then it might not be sensing neutral as JB suggested. I would sure be looking for a faulty safety interlock if there was no problem with the battery and the starter would not operate.
/ RTV won't start #5
yea giggle the shifter if that don't work check the solenoid . the way to check the sloenoid is to jump the starter off from the back of it "atleast thats the old way i do it" if it still don't do nuthin then it's the starter. oh by the way how old is the rtv?
/ RTV won't start #6
TOMMYHPX4X4 said:
yea giggle the shifter. . .
I can see him now, standing at the shifter going, "Tee-hee-hee, tee-hee-hee.":rolleyes: Didn't you mean jiggle the shifter, Tommy?:D :D
/ RTV won't start #7
ok ya'll got me . i did mean jiggle. but you know us coonass's. giggle/jiggle is da same .lol for a second i thought i mispelled the other word and was telling him to jiggle the sh***er .lmao
/ RTV won't start
Dang it, I got power to the starter but don't know crap about all this neutral jigglin safety switch. All I know is the thing won't start and the battery is good and I got power to the starter. I have checked all fuses and they are good. It is in neutral and no the fuel ain't gelled in this 60 de freakin gree heat. The flat lead on the selonoid is also showing good with the test light.
/ RTV won't start #9
So it does absolutely nothing? Like one of the other guys said saying "it wont" start doesn't help much...
/ RTV won't start #10
ok on the solenoid there are two places where the wires conect try jumping it right there"touch the two together" that will tell you if the solenoid is bad. if it still doesn't do anything i put my money on the starter.that is if you jump the right wires .
/ RTV won't start
Tested as recommended, it was the starter. Dealer and parts store both said that you have to buy both the starter and selonoid. Dealer was $285 parts store was $168. Installed and working fine.
/ RTV won't start #14
Glad you got it fixed. I saw a guy on Ebay selling them for $169 when I was searching to try and find a picture of your starter. The $168 is probably as good a deal as you could find. Can you tell us what the "parts store" is? NAPA? Other? I think I discovered that the starter used on the RTV is the same as several other Kubotas. I'd bet that is why you found it other than at the dealer.
/ RTV won't start
Parts store was NAPA.
/ RTV won't start #16
Searching to find info on your starter was very helpful for me. The starter on my tractor from New Holland is around $600. Just the solenoid is over $300. I found starters for the Shibaura N844 and N844L engines for $169 and a complete rebuild kit for $79. If I ever need a new starter, I'll be prepared. I would have never found this if I hadn't been searching for your RTV starter.:D
/ RTV won't start #17
was it the brushs in the starter ?if so could it have been cheaper to rebuild it?did you take it apart to see?i paid i think 70.00 for the brush kit for my hpx starter to rebuild it verses buying a new one. next question do you still have the old starter ?if so why not try to rebuild it and keep it as a spare being you already bought one to replace it. i don't think you ever posted how old the unit was unless i missed it.
Sterling AT (A63118)
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2009 John Deere Z925A Zero Turn (A63116)
2009 John Deere...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
