RTV tools for BX
/ RTV tools for BX #1
Tommy V
New Berlin, WI
BX24TLB
This is my first post after getting lots of good information before and after purchasing my new BX24 last fall. I was surfing the Kubota website and found all the accessories for the RTV vehicles. All the tools run off the hydraulic system of the RTV unit. I wanted to know if anyone uses any of these tools on their BX. Does anyone know if they would even work, I would guess they would hook up directly to the outputs for the backhoe? Thanks everyone for the past and future information.
/ RTV tools for BX #2
There are some pretty nifty tools.
Here is the link,rtv tools
I wouldn't mind having a post driver.
I am not sure they would be compatible with a bx hydraulic system.
They would have to be able to pass hydraulic fluid through them when they are off.
/ RTV tools for BX #3
thats an interesting idea. I think the tools are in bypass when not in use, so you should be able to run them off the backhoe loop. The tractor should be capable of cooling the oil, so I'd guess it will probably work. You would defentialy want to keep an eye on how hot things are getting.
/ RTV tools for BX #5
Might anyone know if the new RTV1100 has the hydraulic output to operate these tools?
Thanks,
The Gardener
/ RTV tools for BX #6
Never knew Kubota offered hydraulic tools.
I'm interested in the post driver and Hydraulic pruner if compatible with my Bx23...
/ RTV tools for BX #7
Man, I'd love to hear how a hydraulic chainsaw sounds. The clatter of my Husky does get wearisome after awhile...
/ RTV tools for BX #9
I just read a hydraulic chainsaw was $2,400.00....... not sure its the same brand, but i suspect none of that equipment will be (what the average guy would consider) affordable.
Of course, that doesn't stop me from wanting one of each..........:mad:
/ RTV tools for BX #11
What is the hydraulic gpm rating for the RTV900 to operate the chainsaw and the other accessories ?
/ RTV tools for BX #12
Dragging hydraulic lines around with my chain saw sounds like a real PITA to me. I'm thinking the only advantage may be more power in a lighter package, but there are still those hydraulic lines. It would be no good for limbing out. The lines would always be tangled in branches.
/ RTV tools for BX #13
I would think the hoses would be a nuisance to contend with.
/ RTV tools for BX #14
After further thought and reading the comments made by many of you who have shared your insights and opinions, I agree that the hoses would be a nuisance.
I have seen the light. I'll stick to my trusty, well used, gas chainsaw.
The Gardener
/ RTV tools for BX #15
I've said it before on here and I'll say it again, stay away from add-on tools with these closed loop Kubota hydraulic systerms. Use your PTO to drive an independent pump to supply auxillary equipment. If all you guys could see the comtamination issues I see in my business you'd understand where I'm coming from. No DIS intended. I'd like to have the opportunity to consult with the Service Engineers on w3.kubotalink forum with what I see going on in the field. Warranty would have a new meaning I tell you....
/ RTV tools for BX #16
I got the following back from Kubota:
Good Afternoon,
If you have the correct coupler fittings, they should work, however, Kubota
does not reccommend the use of these tools on anything other than the
approved application. Using these tools on unapproved application, will
lead to the voiding of your kubota and stanley tools warranties. I hope
this information is useful. Thanks.
JOHNSON 1R POTATO HARVESTER (A64278)
JOHNSON 1R POTATO...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2022 EZ-GO ELITE...
EZGO (A64557)
EZGO (A64557)
2005 Dodge Dakota 4x4 Crew Cab Pickup Truck (A64556)
2005 Dodge Dakota...
