RTV snowplow suggestions
   / RTV snowplow suggestions #11
The Kubota front blade is hyd. lift(electric) and there is an optional hyd. angle that uses the rear remote valve that controls the bed dump.
   / RTV snowplow suggestions #12
We custom fabricate full hydraulic plow blades on Kubota RTV's. We use 72"-11ga trip spring plow blades with hydraulic lift and angling. The hydraulics are controlled by a joystick valve located in the operator area to the right of the drivers seat. The hydraulics give you 30 degrees angling right/left, and 30 degree lift with 15 degree down pressure. The joystick valve has a float position which is recommended for plowing. We use a quick release mount with hydraulic quick connects on the front of the RTV. All hydraulics are run by the auxiliary hydraulic system. The auxiliary back plugs and the box dump are not affected by the front hydraulic circuits used to operate the blade.
We have several pictures of the blades we have mounted if you would like more information.
   / RTV snowplow suggestions #13
I would be interested and seeing some pictures and more information on the product.
Thanks,
Tracy
   / RTV snowplow suggestions #14
   / RTV snowplow suggestions #15
Tracy,
Send us an e-mail and we would be happy to reply with pictures and additional information.
Actually, a couple months ago, one of our customers posted some of our RTV Blade pictures in a TBN thread. We would be happy to send them to you directly.
   / RTV snowplow suggestions #17
Thanks,
Tracy
Tracy,Michigan Iron made my electric lift curtis snowplow into a full hydro,angle& lift.I could not be happier with there workmanship & service.GREAT folks to deal with.coobie
   / RTV snowplow suggestions #18
Hey All,
Check out Kanlan Attachments. They make an awesome folding V blade, sweeper, and sander for the RTV.
Take a look at thier website at www.kanlan.ca
or some of their videos on Youtube at YouTube - KanlanAttachments's Channel
Give me a shout if you need more info.
attachment.php
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
2015 FREIGHTLINER M2 BOX TRUCK (A58017)
2015 FREIGHTLINER...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2017 Ford F-250 (A55973)
2017 Ford F-250...
