rtv snow plow
   / rtv snow plow #1
gates
Maryland
JD 6410 Cab MFWD & FEL,JD 4610 MFWD & FEL,JD 4720 Cab MFWD & 400CX FEL ,Kub. RTV 900W,Hon. Rincon w/plow,Yam. Grizzly,Case 1845C,580L,580SE,Terex 636,Grasshopper 428D,Takeuchi TL 150,Brush Bandit 150
Can a front winch be used to raise and lower the plow? If so rather then buying a power unit for the blade, buy a winch. At least you can use the winch for other options.
   / rtv snow plow #2
It probably could but it would be realllll slow..
Frank
   / rtv snow plow #3
Which RTV do you have? If it is the Worksite or Turf model you already have hydraulics and can lift it by adding some steel and a cylinder. I agree, a winch is too slow!!!
Lorn.
   / rtv snow plow
I have the worksite. I was just attempting the old, kill two birds with one stone. The blade on my four wheeler works with the winch. This is where the idea came from.
   / rtv snow plow #5
gates,
Welcome to the forum.
Check out www.hunterworks.com
I think he has a setup for raising the plow with the winch.
   / rtv snow plow #6
My personal opinion would be use the winch. The electric/hydro factory lift is not very speedy.If you are not looking for speed use the winch.
John Deere Z915E (A50121)
John Deere Z915E...
2018 Toro Groundsmaster 7210 72in Zero Turn Commercial Mower (A50322)
2018 Toro...
John Deere 260E DOBBS Off-Road Dump Truck (A50322)
John Deere 260E...
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
