Rtv Range Select
/ Rtv Range Select #41
i have the old style serial #16500 or somethiung close to this it the old style i believe but i love the abrupt stop just got to get use to it .i wil ltry to wait a few second when i stop but the only thing i have found that works is to turn the key off take out of gear and start back. the emergency brake method does not work for me
/ Rtv Range Select #42
Kabootie, you need to make sure the small tie-rod going from the speed control lever is adjusted correctly. when the spring returns the speed lever to the stopped position (where the roller bearing bottoms out in the lever) the hydraulic actuator on the top of the transmission could be out of adjustment and be supplying enough hydraulic pressure to the tranny to make shifting difficult.
With the engine off, have someone cycle the accelerator pedal and make sure the speed control lever is returning back to the full stop position (bottoming out in the speed lever cam). Make sure the linkage is not binding anywhere (including the dampener stroke) and that the speed control assembly is properly lubricated. Also make sure the cam and roller are clean (no buildup of crud on either).
Also, try raising the rear of the RTV on blocks (in 2WD not 4WD) to see if there is any creep in the drive train after the speed lever returns to fully stopped. If there is any creep, the tie-rod linkage needs adjustment.
This is my country thinkin' just looking at the way it all works.
Do at your own risk. /forums/images/graemlins/wink.gif
/ Rtv Range Select #43
I agree it must be an adjustment issue. I have listened to a lot of discussion about it not shifting on hills but I have always been able to shift on hill. Yes, I do have to wait about 3 seconds for the unit to settle and the gear shift to release but then it comes right out of gear and right into the next gear. It may be that the adjustment of this HST system is just more complicated than the local dealer techs can handle. It won't be the first time a MFG made something the dealer tech didn't understand. Engineering and technology seems to be way ahead of local training everywhere these days.
Good Luck,
/ Rtv Range Select #44
i will check it this weekend when i have time thanks for the info. sound like you know your stuff. thanks
/ Rtv Range Select #45
All of these posts were based on this statement!!
"I specifically asked the salesman if the fluid had been changed on the demo, because I had read that former post. He claimed the 50 hour service had been done, but it was still pretty tough."
At this point I would either asertain that Super UDT was used or replace NOW with Super UDT!! IT Really does matter and many dealers believe that UDT is just as good as SUPER UDT and is a lot cheaper!!
Ask youself how would a salesman know which UDT fluid the Mechanic used in the first place!!
Regards,
Dean
/ Rtv Range Select #46
it does not make any differents my was replaced with the super udt and if anything its worst.it just about felt like i was bending the lever the other day backing up a hill to turn and i tried to get it out of reverse and eventially had to shut the engine off to get it out of gear i give up on trying to fix the problem the only thing i know is to try not to stop on a incline of shut the motor off sometime i wish i bought a rhino
/ Rtv Range Select #47
</font><font color="blue" class="small">( sometime i wish i bought a rhino )</font>
I did after some issues with the RTV. It gets picked first almost everytime for riding. Only when I'm loading up with tools and supplies to work does the RTV get used. Besides, you need to wear ear plugs on the RTV because of the driveshaft rattling. /forums/images/graemlins/frown.gif
/ Rtv Range Select #48
Can anyone tell me if I get the old version speed control put on mine what noticeable difference I will see? Will it be more abrupt stopping and easier shifting; and from what I hear more owners prefer the old version. I'm getting ready to take it back to the dealer for the drive shaft fix and fogging gauges issues and want to get everything fixed once and for all. Which brings me to another question, did the redesigned driveshaft assembly fix the driveshaft rattles? I've been hearing mixed opinions. Finally, done with the questions. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Rtv Range Select #49
Tact,
Check out this thread
Yes, it will stop more abruptly and should be easier to shift. The abruptness can be controled by feathering back on the pedal to control how quickly it stops.
I have yet to hear that the correction for the rattle in the driveshaft works long-term. For those that have replaced the yoke/universal, the rattle did return. I have a new yoke myself but have yet had a chance to replace it.
Brian
/ Rtv Range Select #50
Thanks Brian, I think I'm going to get mine changed.
/ Rtv Range Select #51
Well............
I got my RTV back yesterday having changed the driveshaft and new speed control. So far rattles are gone and the machine stops very abruptly. It's going to take some time to get used to.
The main problem I have is with the speed control change. Now when accelerating from a stopped position it feels like the emergency brake is partially engaged. I don't know if they didn't adjust the linkage properly or if this is just one of the changes I have to live with. It's like more power is needed to get it rolling. I've also lost about 3 mph as I've heard someone earlier stated. Any help with the linkage adjustment would be greatly appreciated.
/ Rtv Range Select #52
After the change to the old style I noticed the dealer left the damper secured in the lower position. Is this the correct install? Seems like I read that the damper should be positioned on top of the bracket.
BTW The driveshaft rattles are back and LOUDER!! /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
/ Rtv Range Select #53
The damper is supposed to be installed opposite of what you had now (in the upper position), it's just a matter of some crotter pins to install it correctly.
/ Rtv Range Select #54
Trying not to be confused, but are you saying with the "old" style the damper is supposed to be on top? Thanks for your help.
/ Rtv Range Select #56
Thanks for the pic. Can anyone tell me what effect it had with the damper install opposite from what it should be with the old style. I change it but I can't tell any difference in the way it operates, or should there be any noticeable difference?
/ Rtv Range Select #57
The only noticeable difference would probably be in the amount of time it takes for the VHT to return to the natural position (longer when incorrectly installed).
/ Rtv Range Select #58
Tact,
I've been offline for awhile. Is your speed control all set?
I tried both versions and personally found it was the "non-abrupt" version that gave me a loss of speed.
Brian
/ Rtv Range Select #59
Hi Brian,
Long time no hear. /forums/images/graemlins/grin.gif
I went back to the old style version and noticed the machine straining on acceleration from a stand still. I also noticed the difference in the abrupt stopping, which I am becoming accustomed to. When I began to look at the setup closer I noticed the dealer had left the damper in the original position so I reversed it for the old style, putting it on top of the bracket, and it helped it tremendously. I'm still working on getting used to the stopping. I think it will be fine as time passes. Now the only open issues are the driveshaft rattles and th fogging gauges. I spoke with the rep from Kubota last week who stated there still are no fixes. See you on the forum.
Fred
/ Rtv Range Select #60
Brian,
I forgot to mention that with the original old version speed control I've lost about 3 mph top speed in high range.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
PALLET OF LIFTING STRAPS (A68842)
PALLET OF LIFTING...
T/A Dovetail Flatbed Equipment Trailer (A66736)
T/A Dovetail...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
2018 MACK LR633 6X4 TA GARBAGE TRUCK (A66091)
2018 MACK LR633...
